Well i service my car every 5000km with Royal Purple 10W40 and ALWAYS warm up my car before i drive and ALWAYS cool it of for 3 min before i turn it off.. so these precautions should maximise turbo life...
I want to stick to BB highflow cause of quality, longer life as well as proven earlier spool which is what makes it more streetable...
im still waiting on Trooper to PM me the specs and price for this new bolt-on Turbo from Garrett...
One more thing guys, you think its work upgrading the stock manifold and cams?? how much increase would they give with a decent high flow?
Cheers
Edited by QRI05E
  • Replies 44
your manifold is fine tho you may get fast spool with a
stainless tuned length job but for the outlay of a good
quality not really worth it i think , looks pretty for a little
while tho, and cams you could get some tomei's good idea
if planing around 260rwkw up ,will give you better response, but being a
hightflow and BB wont be very laggy ,but you will have good mid
to top with cams, you can alsways do cams later idown the track anyway.
thats my 50c. :(
Cheers
Yea thats my exact thought too.. can do the cams later on if needed... my list goes as the following:
- Highflow BB turbo/Garret bolt-on
- Apexi PFC + Tune
- Eboost 2 (or any decent EBC)
- Z32 AFM
- SARD 600cc Injectors
- Tomei Fuel Pump (was considering Walbro 255lt/h)
- Just jap FMIC Kit (painted black)
Anything that im missing?
Cheers
Edited by QRI05E
on a related note, would it be safe pushing the stock internals around 260 - 280rw/kw?
Please comment on the parts i have listed above if you guys recommend anything else...
Cheers
many people have made more than 260rwks with the mods u have indicated without having to change internals. When u approach the 300rwks mark, then ud def need to strengthen ur bottom end, ie pistons, connecting rods, crankshaft.
- Apexi PFC + Tune
- Z32 AFM
Cheers
Hey,
I pretty much have these exact mods except 555cc injectors and profec BII and GCG hiflow. was having pinging problems dude to bad fuel, i had to add octane booster to compensate.
Be good to compare though, even though different car blah blah blah.
Think i saw you yesterday going down cowpasture road.. i was in the white R33.
Currently have bout 180rw/kw and aiming for 250+rw/kw
Hahaha yea that was me... were you in the White R32 heading toward cecil hills? hehehe should organise a cruse or just a friendly meet...
Edited by QRI05E
Ahhh yes i remember... hehehe was hoping you would give it a squirt to give you a run... ur car seemed stock lol... wat sort of power figures you got at the wheels? and who did your work for you??
Cheers
yeah i like keeping my car looking stock.. catch a few unsuspecting foes. Plus if i get owned hard, i can say yeah my car is stock.. hahaha i would have given it abit but being double demerits and all i had to restrain myself.
Tuned by Unigroup Engineering, 240rwkw on 16psi. gonna take it back when i get some good fuel in there hopefully i can get abit more power.
thanks man, nah my knock sensor would have been flashing at me.. so you would have beaten me.. hhaha. It runs fine when i put V-power racing in it.. but when i put BP ultimate it pings badly.. i drove up to the shell there to get VPR but they were out of stock so i went back to BP to get ultimate, when i pulled out, that's when you saw me.
Gave it a hit on the way home and the light was flashing.. it was tuned on BP ultimate as well.
haven't taken it to wsid yet.. wanna sort out this pinging problem first.
Damn those British and their Petrol :D I always use V-Racing or Vortex... my car seems to dislike Ultimate too
Well ill be getting Adam at JEM to tune my car and i have seen some ANIMAL R33's step off his dyno... so i cant wait to do it all...
Cheers
good luck man, i heard JEM do great things..
Definately keep me up to date with how you go.
Oh i had to get new coilpacks as well as i couldn't boost past 10psi before without misfiring... There's always something!! but the car made 220rwkw on 10psi.. now no misfire but damn fuel problems!!
Definately hook up for cruise.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
