Gsm Sms Alarms
weSky
 Share
Guys,
I need an alarm with GSM SMS with both function and messages (ie: you can send commands to the car via SMS and get general messages from it - ie: "help, some dic just broke in to me" haha)
So far all i can work out is that this type of thing is really just a module/addon to an existing alarm? I am pretty dumb when it comes to this stuff.
In saying that - I need something that has an immob, alarm, door openers (no boot), GSM SMS + a remote control to stick on a keyring (stuff sending a text each time i need to open my door haha)
It would be going on a GSTS R33 2 door manual. There isnt a turbo timer and i dont plan on installing one.
Can someone give me any suggestions and prices (with install) or better still, a place around melb that contains workers who do not have their heads up their backsides - melb seems to contain most of these loons.
I live in Melb and please dont tell me to go to Autobarn - i got the reply of "What do you mean a GSM SMS capable alarm, there is no such thing" - god damn I hope he isnt right haha.
Cheers,
Steve.
Edit: While I am at it, will the below alarm do all that I need. Im assuming I will have to pay extra for it to be tapped into the cent' locking? and of corse, install.
http://cgi.ebay.com.au/NEW-RHINO-RAM-Dual-...VQQcmdZViewItem
Edited by weSky
From my researching most alarm installers will put a decent alarm with a decent gsm module. ie. Mongoose alarm with mongoose gsm sender. This setup would end up costing around $1000~.
With $1000~ id prefer the quiktrak, which is on special for $999 incl installation but a $400~ yearly monitoring fee has to be paid.
The only one i could find is the rhino gsm alarm floating around ebay. Although i cant find a reputable installer as most decent installers only stick to their alarms.
From researching about the rhino, it has a normal alarm keypad and can also be controlled via sms, if you lock your keys inside car etc.
If you get the rhino please keep us updated with it as i would like to see it :)
Cheers
There is a module compatible with the Autowatch 456RLi
Alarm Cost = $600 installed
GSM Module = +another $700 installed and configured.
I think this allows for 2-way messages.
eg Module sends message if alarm is triggered
Module can receive message and wind windows down
yep CATE. cool module and its LOCKED to your phone via password. has 4 outputs that can be configured to do what ever you like.
rhino ram has 4 or so aux outputs to do w/e u want, also shares the password feature you speak of, what do you mean by *tamperd* with.
the CATE is an entirely separate unit so if you find the alarm you wont find it. in the case of the Rhino item find the unit pop the card out and its gone.
comes back to installation in reality.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
