Hey all,
If you're looking for some fat wheels without having to go 5 stud, then these are for you...
Came off my S15 fronted sil. Rears will fit with some flaring.
Work VS-XX - Finest 3 piece Modular Construction, Super Lightweight wheels with reverse outer rim.
4 hole - 114.3 PCD
18x9.5JJ off +19 - Toyo Proxes4 225/40ZR18 Tyres - 90% tread (slight camber wear on inner edge)
18x10.5JJ off +19 - Trampio Guwn 245/40ZR18 Tyres - 80% tread
These tyres alone are worth big coin...
One wheel has a small section of minor gutter rash, the rest are basically flawless except for some small light, scratching (normal wear basically). Awsome condition!
The fronts have a good 70mm worth of dish and the rears, 90mm!
Come with all 4 Work centrecaps.
All wheels have recently been balanced.
$2,500 FIRM
Located in Adelaide, SA.
Can deliver to your door anywhere Australia wide for $100!!
PM with any questions/queries.
Edited by driftKNG
Hey all,
Tyres are sitting around doing nothing so it's time to go...
Here's the rundown:
16s
- 4 x BRIDGESTONE TURANZA ER30 - 205/45R16 - 70% - SOLD
17s
- 2 x BRIDGESTONE POTENZA RE050A - 215/45R17 - 70% - $100
- 2 x BRIDGESTONE POTENZA G3 - 255/40ZR17 - one at wear indicator, one with 2mm+ indicator - $50
18s
- 2 x PIRELLI PZERO ROSSO - 255/40ZR18 - 60% - SOLD
- 2 x BRIDGESTONE POTENZA RE040 - 235/40ZR18 - 70% - SOLD
- 2 x BRIDGESTONE POTENZA RE040 - 235/40ZR18 - 50% - SOLD
- 2 x SILVERSTONE FTZ SPORT EVOL 8 - 235/40ZR18 - 1 BRAND NEW /W NIPPLES, other 95% - $300
Will not be taking pictures. - Come round and check em out if interested. Prices are firm.
Cheers!
Edited by driftKNG
- 2 x BRIDGESTONE POTENZA RE040 - 235/40ZR18 - 70% - $100
- 2 x BRIDGESTONE POTENZA RE040 - 235/40ZR18 - 50% - $50
I'll take these off your hands. Today if you're available. Would like to inspect them first so if I could get your address that would be sweet! I'll PM you too.
cheers mate
How much to ship the 2 pirelli pzero 255/40/18 to sydney?
Also, I am keen on the gram lights, but why only 235's on them?
Great looking wheels and GL with the sale !
I just wanted to know what courier company you use to get :
"Can be delivered to your door ANYWHERE Australia wide for $100!!"
I ve got a set of wheels i need shipped across the country and I'm in need of some advice, if u can help ?
PranK - It will cost you $65 to have these sent to your door in Sydney... Unfortunately there is a minimum charge associated with items of this nature. >_<
I put 235's on the Gram Lights because I feel this is the best profile (looks wise) while still maintaining drivability. Anything more stretched on that width starts to get a little dangerous. Suits these wheels perfectly!
:laugh:
Edited by driftKNG
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
