RB20 rods are the same length as rb25 and 26 little end pins or gudgen pins also the same dia only differance is the big ends are smaller in the 20 rods .I had all three measured up for my rebuild just b4 xmas
Rb26 rod on the right rb20 rod on the left
Cheers Peter
thanks that solves allot of problems but i was wondering if the cons are the same thickness. when i looked on ACLs website it sais that the bigends on a 20 are 16.1mm and on the 25/26 its 17.1mm i was wondering if this is the same at the top of the rod as i am planning 2 put the 20 cons into a 25/26/30 piston and dont want to have to pack it out
From our measurements they atr the same it just the bearing cap width thats differant
1st pic rb26 rod on the left ,2nd pic rb26 rod on the right ,bith rods number 1
cheers Peter
thanks for that got all my research now. just need 2 start collecting the rest of the parts. iv been given a 25 block and have a spair 20 for the cons and crank all i need is a head and a set of pistons im bidding on a set of 26 as these will decrease the comp for the turbo otherwise it will b a set of 30s
me again
i was at the libery 2dy n i looked up the vl comodore repair manual (dident have a skyline 1) and it said that the small end pin in a rb20 is 19mm and the rb30 has a 21mm
i was wandering if someone would be able 2 put a micrometer in a rb20 conrod and c what the internal diameter is
iv already tried going 2 part dealers and asking 2 c there catalougues but they seem 1 miss out this detail for the 20s
Doing a good job dude, really interested to see how it works out !!
I don't see why 500rwhp would be a problem with an rb23.
There a rb23/24 in Japan that runs low 10's, thats gotta be close to 500rwhp.
SR20's do 500rwhp to so its not a capacity thing. I think just a matter of getting the intake manifold and head to flow enough air.
Don't be too afraid to have a go at porting yourself. You sound like you have a fair idea. Porting is not the mystical beast a lot of people think it is.
Wish all the rb20 haters would shut up and leave this thread alone though ... Sure sure there is logic to do rb25/26 but why not be diffferent FFS !!
Right on, some inspiration!
My plans have changed a little for the near future.. As much as I'd still love to do this, the car is my daily driver atm.. I dont want to wait 6 months to drive because of parts on order.
For now I'm doing some bolt on power upgrades that will help in the future stroker/built motor, and in the present stock/reliable form.
Fitted my GTR cams - woot!
can u give us some more detail on how exactly n where 2 grind it out
i found this is this what ur talkin about
http://www.chevyhiperformance.com/techarti...ting/index.html
Edited by johan.p.g
Check out this site I bought there deluxe porting tool kit and do my own heads comprehensive guide with it to
http://www.sa-motorsports.com/do-it-yourself.aspx
good luck
Cheers Peter
thanks il giv that a read 2nt n practuice on 1 of me spair heads
im buyin the new head 2mo n also pickin up the block from a m8s place so im well into it now still need pistons though n im skint
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
