well i always thought of da v/top mount coz of dat fact ur awayz getting ar in even if sideways + shorter pipes + more room for MASSIVE radiator nd twin fans (tripple fans ? :) )
but den again wudnt realy want 2 cut bonnet up nd access for engine wud be a lil bit limited
ok lets switch this thread up a bit... we in theory know that this wont work well due to the amount of heat and air blockage...
Now lets throw in the AC cooler... how would you fit that into the equation if removing it is not an option?? i was thinking of pairing the AC cooler and the radiator together on the bottom of the V-mount... with the cooler in front of the rad.
mount it underneath the radiator so that gets bashed before the radiator does :laugh:
ok final solution... sorry would have got pics but i forgot to take my camera.
but the run down is a comprimise and cost effective...
GTR intercooler mounted upsidown where the radiator sits, radiator mounted behind it (AC removed for other reasons) gotta see it to appreciate it, the piping is so short, everything is protected by the core support and all at almost no extra cost... ill try to mock it up again tommorow for pics... but i might have to wait till i get some parts from the US and complete the install...
actually it's quite scientific as to why intercooler belongs in front of rad. It's called counter current exchange in animals (which is where I learnt about it anyway) it's basically the optimum way to transfer heat between fluids. The underlying principles are well described here: http://en.wikipedia.org/wiki/Countercurrent_exchange
Shortening the length of the pipe will reduce lag, however you are sapping the IC of most of its efficiency, it is only cooling air around what? 40 degrees? as opposed to your radiator which is cooling water from around 80. You would basically reverse the counter current exchange.
Edited by Sarumatix
basically what was said a page or two back... but thanks for the recap....
I'd like to see this new setup 4d-whore. Sounds cool.
If you WERE going to keep the aircon with a V mount, I would say it'd be best to put it right in front of the V mount. i.e.-
_
V
r
e
s
t
of
c
a
r
The air condenser isn't very hot after all, and due to it's size wouldn't block enough air to matter much at anything over 20-30kmh - maybe under it would make some difference however.
I think so long as air is being forced into each cooler properly with baffles/air dams it'll be ok. Without that I don't think it'd be anywhere near optimal efficiency. If you're not going v mount and you want that little extra you should try a small lip (like garden turf size) below the engine as well.
haha yeah its pretty thin but unfortuantly we had a conflict cause one system was R112 and the other was R134 or somthing... i wasnt to keen on keeping it anyways since it weighs like 70lbs... thats about 5 horses right there.. and it was just annoying i dont mind not having AC i told my jap friend that if he wants it he can transfer it himself haha... the japanese are pussy's when it comes to hot weather and rain...
i hate the cold myself...
Edited by 4DoorWhore
they cut the entire core-support out of the car to do that... i was moving my dummie rad and core around and just couldnnt see any better way to do it then the setup i picked... vmount is more efficient but the cost changes a bit... but i think the response will be the same between the two
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
