hope you lot can help with this prob ive got.i'm fitting a ats carbon twin plate to a r33gtr,clutch was dropped off with the car all looked ok,at the time i wasnt told that you needed to fit parts from a r32 to convert to push.i had a os giken conversion and thought it would do the job,but no you cant even get the box on with the ats and the os conversion kit.the pivot bracket hits the pressure plate and it just dont fit.
the clutch that was removed was finnished and so decided to fit my own giken triple off my 32 with the conversion kit and at least it will be back on the road,but now after removing all the excess pipes from the 33 and just having one pipe from clutch master to slave and bleeding it all it still dont work properly,the conversion kit has a adjustable rod and if adjusted as you would normaly it does'nt disengage clutch and no gears can be engaged,if you wind out the rod you can get gears but when driven clutch slips.
its like the slave cyl has air in it and has'nt enough travel.
any ideas to help with this prob?????
oh and the os clutch was out of my 32 and worked with no probs.
thanks
https://www.sau.com.au/forums/topic/148617-r33gtr-clutch-hell/
May be able to help. Alternative if you want to run the ATS carbon would be to swap the R32 bell housing and gear onto the R33 Box, which is entirely possible. But check the bellow first.
On 33GTR's and 34's (not sure about R32) the clutch line comes down from the clutch master cylinder and into a junction box (T-piece if you prefer) From the junction box thier is a pipe leading to the flex pipe which goes into the clutch slave cylinder which in turn has it's own bleeder nipple that needs to be bled.
But before bleeding this part you need to perform a bleed at the junction box. The junction box has a big loop pipe which comes back into the junction box. I assume this loop pipe exists for extra volume of fluid or for cooling reasons. Right where this loop comes back into the junction box there is a bleeder nipple. Bleed this first, then the slave cylinder and make sure you don't run out of fluid in the resevoir as it's pretty small.
May be the solution.
i removed all the extra pipes as i have bled them before and they can be a pain,so i have run one pipe from the master to the slave and defo has no air in it,just looking for a broke 32gtr box to pull all parts off and try on the 33, with the ats twin.
Yep will work. You can seperate the bell housing from a 32 box and put onto the 33 along with the push type gear and use the 32 slave cylinder. Just make sure you get the selector ball bearing thing out before seperating the box other wise this will fall into the box.
Have you done this before? If not refer to manual.
just found a r32gtr box thats broke 3rd gear,will remove all the parts and give that a try,not done it before but have got the manual to hand(and a big hammer) :cool:
will post up later how it all goeas
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
