wtf?? a rex?? are you serious dude. no chance.
yes man, wrx are very much unique, from their boxer engine, their topmount ic, to their own awd management systems that battle the EVO's.
If you mistook the way he said "Like a WRX" to refer to the topic of this post, then yes this Falcon don't sound nothing like a WRX. or a skyline. But unfortunately for you he was only saying that wrx and skylines are both unique.
Some HEAVEY decibel science going on here... :P
Most Over head cam injected 6s can sound similar depending on situation
with the turbos dampenig the bang's, same goes for none turbo which usualy sound disgusting large diameter unless thought about...
The rexs take a bit to get used to sound wise as the boxer config tends to muffle rpm sounds together
3000 rpm sounds like 1500 etc
    • I hope one day I can do it like you. Your engine looks great.
    • If there's nothing else I can do I'll probably do something like that Someone on the internet said that ca20s and ca18 engine blocks are the same and that you can use a ca20 engine block and put ca18det parts to make a ca20det Do you think this is possible or will it damage the engine?
    • Yeah, I did some research and found out that some things are different.
    • Makes sense, thanks! Consider me very impressed. And I very much appreciate the effort in documentating all of it. You'd be surprised, or maybe not, how many people this reaches who search for things online. Anyways, I shall continue to read all of it, understand maybe a quarter, and hope that some of it sticks if I ever end up in a situation where it's relevant
    • 'Did' work on them is more accurate ~ on the R31 Skyline forum, you can spot me as 'Solder'... I've written quite a bit about the 4R01 boxes there, and I ended up reverse-engineering the older TCU type operations, so we could fudge a custom TCU to pull off other tricks...and like all things, when you do it a lot, see the failure patterns, have to find parts etc etc, your head ends up filled with whys and wherefores... there was a reason Nissan went with these in more than 60models over 16+ years... all in all, the JR401E based design is an interesting study, as Nissan changed things over the years in a never ending battle against them lunching on themselves <grin>...by the time the RE4R01A rev.C came out (often referred to as RE4R01B), they'd more or less perfected the design...
