As i'm slowy getting ready for my highflow build, im also going to purchase a FMIC kit.. however i want a black FMIC with black pipes purely for the stealth look behind my R33 S2 bar... does any company make such a FMIC kit? or would i have to paint it?
Cheers
Edited by QRI05E
  • Replies 120
on the same note, what exactly is entailed in painting a FMIC.. im guessing you cant just spray the whole front of it black ? do you need special heat resistant paint or what ? anyone done this before ?
This was from the autospeed site
"We have seen conflicting literature on the matter but our testing leads us to believe that a black painted intercooler performs better than a bare one."
There would be a poofteenth it in......Unless your going for that 0.0001 of a horsepower (exaggerated).....Grab a can of VHT flameproof for the sake of it....(thats if you can find some, seeing VHT plant blew up a while back) and aus is struggling to get most of the VHT lines in the country....
ne hoo just paint away
-Jez
One thing you have to be careful of though is making sure that the paint doesn't build up in between the fins and cause a restriction, so make sure you use a 'thin' paint and a couple of light coats.
Other than that any automotive paint will work fine, even the general shit you buy at bunnings will do the job provided it applies to a metal surface.
Thanks for the reply guys, my aim is NOT to chase 0.00001 hp gain but to have it hidden behind the front bar and not noticable... im sure if i just spray it black it will flake off after a few months from the hot and cold temp changes...
I dont want a GTR FMIC cause i prefer a kit that comes with all the piping... dont want to have to make up custom pipes...
Is the Nismo black FMIC still in production?
Cheers
Cheers
I did the same with my old FMIC and cops stopped pulling me over once they couldnt see this big silver as with it blackit wasnt obvious. People even asked me why i got rid of my front mount, when it was clearly still there
Black fmic is the way to go. Went through a defect station at milton maccas one night and they didnt pick me up for it. I also have black painted cooler piping throught the engine bay so i think that helped. I gave my cooler a respray about 3 months ago as the original black from the gtr cooler had started to break off. I just used some standard black spray paint from bunnings, doesnt clog up the fins.
I don't recommend you use just any old paint, it stilll has to have some thermal transfer properties and most paints are an insulator of sorts so the radiator stuff is the go.
Matt black is the ideal property for radiating and absorbing heat with powdered gold being the most matt material known. Polished is extremely poor for radiation. Try your polished exhaust tip after a decent drive, see how warm it feels by putting your hand close to it but don't touch. It won't give off much heat, but if you spray a little water on it will boil off.
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
