  • 4 weeks later...
  • Replies 120
Okay guys, decision time! I have searched with no results….
Powder Coating Vs Anodizing
1. Which is better?
2. Which last longer?
3. Which will act better as a heat “radiator”?
4. Which will be less restrictive for airflow and not clog up the fins?
Any further info would be great!
Regards,
Sarkis
From what i have read up so far:
Anodising is "staining" the aluminium surface at a thickness of approx 0.3 - 0.5mm therefore not affecting its thermal properties.
So looks like anodising is the way to go...
Would really appreciate you opinion guys!
Regards,
Sarkis
As I said before, paint is an insulator, but radiator paint is designed for the job so if you must paint use that. Anodizing is no problem.
Powder coating - you may as well just go back to stock IC or blow up your engine now.
Thanks guys! I have also read that anodising can damage the IC fins due to the sulfuric acid wash.. is this true?
Would radiator paint fade/flake off the polished parts of the IC?
Regards,
Sarkis
I have painted my intercooler black and can't see it making bugger all difference to it's efficiency if done sensibly. I masked up the rear of the cooler and the sides of the end tanks and only painted the front so it looks stealth but still allows the majority of it's surface area to be free of paint.
I bought good quality etch primer and matte black acrylic paint and laid a very light coat of each on the front of the core and end tanks. The primer was just to try and guard against stone chips etc. By masking the entire rear of the core you stop the majority of paint being passed through the core and coating the cooling fins. My cooler still works great.
Thanks for the replies... i wanted to get my FMIC black for the stealth look rather then performance or cooling gains... so far it seems that a VERY light coat of radiator paint or Anodising is the way to go...
Got any pics please krizza_ca18det?
Cheers
I would also be concerned about the durability cause a stealth black intercooler with stonechips/flaking paint will look very shit house and cheap. Would a black mesh insert over the intercooler be a better option and also guard against said stone chips?
Yeah ring around and get a few prices. You have two options in getting it anodised or that radiator paint. If anodising doesnt wreck the fins or look patchy that seems the best option as it wouldnt stone chip. Let us know what prices you come up with for both as im going to get mine done as i prefer the stealthy factory look.
Here are a couple of pics I took of my cooler this arvo. Only one small stone chip after a year of use ( but plenty of bugs! ). I don't have any pics of my mates cooler but it doesn't look too bad. I can't help you with a price either, as his uncle owns an anodising business so he got it done for free.
Sarkis have you seen the avo ones
http://www.avoturbo.com/avoshop/product_in...products_id=241
They make them in black and they use the existing intercooler lines. Easy installation. I will show you my stealthy kit next time.
anodising is so thin it is measured in microns. The longer they leave the item in, the thicker the anodising. Anodising is one of the most hard wearing and durable surface coatings you can possibly do. The intercooler would probably want 5-20 microns, BUT with some anodising on aluminium you get a very Cloudy/ Patchy finish, and can look quite bad.
If you choose to paint it, i would recommend using a thin first coat of etch primer. You can use any automotive paint/laquer on it, heat wont be a problem.....
    • Surely the cam timing is set to something stupid at low RPM?
    • Hi guys, Sorry to butt in and take it slightly off course, although still on the VCAM subject.  I had VCAM put into my Tomei 2.8 bottom end and I struggle to take off because the engine has very little torque caused by VERY low dynamic compression at 60psi. But once off the mark and especially on boost, the engine rev happily all the way to 8000rpm and makes 630hp at 20psi of boost on E85 at the rear hubs. Has anyone had any similar experience or any suggestions on what might cause this low compression at low rpm? I am in the process of converting it into a 8hp transmission and with this low torque, the engine would not even stay running until the throttle is opened to more than 30% and then I loose all vacuum.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
