astlineofdefence - Yea but its bit pricey for my budget... im getting a just jap kit...
HRthirtyone - I spoke to a few places regarding Anodising and they told me that 2 things that may go wrong with the FMIC:
1. If there are any impurities in the aluminium it will cause patches
2. The sulfuric acid MAY damage the fins (its a risk)
So my only conclusion is to get a radiator shop to spray it using Radiator paint.
Cheers
Edited by QRI05E
  • Replies 120
Hey guys, I just spoke to a local Radiator Repair Shop and he recommended the following:
- Sand back the polished areas of the FMIC kit (piping + end tanks)
- Add a brass vacuum nipple to the crossover pipe (for actuator)
- Lightly prime the end tanks and all piping using etch primer.
- Spray the piping and end tanks with Black semi-matt high-temp paint.
- Very lightly coat the FMIC core with Black semi-matt high-temp paint.
$60 - $100 for the whole job (depending on time consumption)
I also called a company that specialises in Anodising automotive parts. They recommended NOT to paint the intercooler as it would insulate the heat and trap it inside.
$160 approx for Anodising a FMIC Kit in Matt Black
Cheers,
Sarkis
Yep thats $160 including piping... but unfortunatly i just found out that the Just Jap FMIC kits have chrome plated piping which means they need to be stripped before anodised...
Might need to get the FMIC anodised and the piping painted?
Regards,
Sarkis
I spoke to Plazmaman who are specialists in intercoolers and they reckon as long as its a light coat of paint, it wont effect the cooling by much if at all... so i dont know who to believe... maybe the anodisers said that painting will insulate heat just to convince me in taking my product there?
From all i have read and researched, im sure that as long as the FMIC core and fins arnt covered with much more then 0.1mm of paint they should still cool the same as bare aluminium. cause the cooling process is done within the thickness of the core not the front or rear surface meaning as long as no paint gets into the fin area, it will have nil effect on its coolong performance. So perhaps use etch primer for the end tanks and piping then spray with high temp matt black... and just dust the surface of the FMIC with high temp matt-black...
Regards,
Sarkis
Hey Guys, just got a quote for $10 from a radiator shop to spray an FMIC kit with black thermal paint...
Wetherill Park Radiator Service
Unit 24/ 274 Victoria St Wetherill Park NSW 2164
ph: (02) 9604 7798
Ask For: Chris
Regards,
Sarkis
hey man, why dont you go with this? why have you changed your mind?
Thats without any sanding, preping or primer... just straight spray on... i dont think it will last long on the polished pipes... rather do it right the first time round.
Cheers
Thanks for the reply guys, my aim is NOT to chase 0.00001 hp gain but to have it hidden behind the front bar and not noticable... im sure if i just spray it black it will flake off after a few months from the hot and cold temp changes...
I dont want a GTR FMIC cause i prefer a kit that comes with all the piping... dont want to have to make up custom pipes...
Is the Nismo black FMIC still in production?
Cheers
You dont have to make up custom piping for the gtr front mount.. I fitted one one my car perfectly.. and just using a standard piping kit..
It cost me $100 or more less then a hybird kit and flows just as good :P
ZOMGGG D I F !!
YOU STILL HAVE THAT ULTRA COOL SIGNATURE!!
GIMME GIMME !!
SO HOTTTT
Please....stop there, no need for fancy work.
Simple light mist coats from a black spray can will fix this issue.....it will not clog up your intercooler etc aslong as u mist it on and dont do thick coats. I dont it on my oilcooler and i would notice the affect much more on a oil cooler and it was 100% perfect.
Chances are your front mount is far to big for your application to start off with and its already lagging your car so black spray wont affect it what so ever. Not being rude.
- Luke
Luke - Im getting a highflow turbo, 555cc injectors, walbro pump, Haltech ECU all fitted... aiming for 250+rw/kw... you telling me a 600 x 300 x 76 FMIC is too big?
Dont think so!
Cheers
Take it to a radiator repair shop and get them to paint it. Their stuff is made for the job.
Hi Geoff,
Do you mind posting up any radiator shops you recommend to take it too? (eastern suburbs :devil: ) Or are the local radiator shops fine?
Any decent radiator shop will do the job... im sure any pannel beater will too...
A black grill is a good idea but the only problem then is the pipes that stick out the side of the R33 S2 bar underthe fog lights/blinkers...
Can anyone please post up some pics of their S2 R33 with grill infront of their FMIC?
Cheers
Don't paint it!!! 0.1mm may sound like not much, but that's 100 micron of paint, more than enough to trap heat.
A lot of the polyurethane paint you see on things is less than that, when you consider a factory car paint job is around 125 micron, that's a lot of paint on your cooler.
Dan what you suggest? The FMIC i can get Anodised but the piping is chrome plated aluminium... how am i going to get them black?
If i anodise the FMIC (end tanks and core) would it be okay to paint or powder coat the piping?
Here is a little edit I done in Photo shop... i really prefer the stealth look....
Regards,
Sarkis
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
