  • Replies 120
I dont understand, if its primarily a track car, why are you painting it? A light coat of paint on the front will be fine, if paint was that bad for heat exchange, radiators wouldn't have been painted for all those years, XR6's and gtr's have black painted coolers from the factory, and it takes 10 years for the paint to flake off, just give it a bit of etch primer on the end tanks.
Ok, so lets say i Anodise the FMIC...
Question: Would there be any ill effects by painting the IC piping black? Cause the stock piping are painted black...
Cheers
Ok guys, ill post up the results next week with pics after all is done...
Anodising FMIC in Matt Black - $105
Painting Piping with Hightemp Paint + Brass nipple fitting - $50
The only reason I am painting the piping is due to the chrome plating.. cant be anodised
Total = $155
Keep an eye out for the results...
Regards,
Sarkis
have to say it looks good against the silver duco...nice one.
I cbf doing all of this so installed some mesh infront of the FMIC and painted that black which has a similar effect of dulling down the look.
khungjeng, could post us a pic of your mesh setup?
just wanting to see how it looks.
Thanks
Yea ill be getting my FMIC kit Anodised matt black.. its going to set me back approx $150 however the benifits are:
- Increase surface area = Better cooling
- Matt black = radiate heat better
- Will give a "stealth" look
- Anodising will strengthen the fins and core
Can't wait to get it all done.. ill make sure to post up before/after pics as well as installation pics
Regards,
Sarkis
Thanks
yeah no problem here u go. Its not like u cant see it...its just a bit dull with the back mesh...also helps catch any big bugs LOL
From Garrett website:
"It is not uncommon at all for an intercooler and endtanks to be anodized black to keep attention away from the car and help it maintain a sleeper appearance. A very light coat of paint on the core and endtanks is also another option, usually much cheaper and easier than anodizing, with a negligible performance loss. "
Save a bit of cash and just paint it...
Not sure if one should take advice from Garrett when it comes to intercoolers.
They have some very poorly designed end tanks.
But realistically a light cost of paint is going to do no worse than one that doesn't clean/flush their intercooler yearly.
its been covered a few times in the 5 pages of this post...paint it sure...but with the right stuff that wont stop any heat transfer.
Personally i cant see how paint on the endtanks and piping can cause ANY heat soak especially when the air is travelling to thise speeds. However i can see how cooling will be reduced by having paint on the core thats why i have decided to anodise the FMIC...
Cheers
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
