The following diagram represents my understanding of the cooling process of an interccoler.
meaning that as air passes through the fins, the "thickness" of the FMIC core is where the cooling process happens. Its the same as when GTR's upgrade their FMIC to thicker cores with same frontal dimentions (ie. 600 x 300) that allows them to run higher boost and power levels. Again the same principal with the R33 Vs R34 SMIC...
So can a light coat of paint decrease the cooling capability of an FMIC? i honestly dont think so.. But for an extra $50 might as well get it anodised...
Regards,
Sarkis
  • Replies 120
Regards,
Sarkis
Hey mate, i just got a price to anodise my cooler and i got quoted 300-400! Think ill be giving it a light coat of matt black primer!
personally i like the silver FMIC thats why I bought it and in the two years of driving coppers have only mentioned it once and i told them all turboed 32's come standard with a FMIC and they listened. (i didnt mention how big the standard is lol) but i do know you can buy black FMIC i cant think of the manufactrer but i will get back to you
Every FMIC expert i spoke to (PLAZMAMAN) said that paint will affect the cooling properties and will insulate the heat in an intercooler. Radiators are made from copper that’s why they need paint to prevent corrosion. All aluminium radiators are raw and not painted...
Anodising is the only method known to not effect cooling properties... for $130 its worth it IMO.
Results & Pics Soon...
Cheers
Edited by QRI05E
Hey fellas, just a quick update...
Today I spoke to the anodizer and he told me something quite interesting...
When anodizing a FMIC, the internal part of the core and end tanks are anodized too meaning this will aid in cooling... Black is known to radiate as well as absorb heat therefore when you have an internal temperature greater then the ambient temperature, heat transfer will be outwards.
Micks Motorsport gets all the FMIC's for their big HP cars anodised for that reason.
Pics Coming soon...
Cheers
I got my FMIC kit anodized at http://www.anodizers.com
There the only place in NSW who anodize car parts...
Cost me $135 + GST = $148.50 Still a good price in my opinion...
Im picking up the FMIC kit tomorrow... will post some pics :no:
Cheers
Pics Coming soon...
Cheers
Hey QRI05E,
This is just to help you out,
There are two main heat transfer mechanisms that remove the heat in intercoolers from the charge air. They are conduction and convection. Now the conduction which happens between either a solid material (i.e. core) or stationary fluid acts primarily as a function of TEMPERATURE DIFFERENCE and material. Also convection which is the transfer of heat between a moving fluid and surface (ie. core to outside air or inside air to core) and it is primarily a function of the mass flowrate.
Now thats a simplified explanation. Heres how it t's into intercooler design and sizing.
For a given heat to be dissipated (i.e. temperature drop of charge air across intercooler) and for a certain intercooler core arrangement and fin type there exists a minimum SURFACE AREA required for this heat to be dissipated. This then equates to the physical volume of the core which you see as frontal area and thickness. Typically thickness is increased as it is easier or the only available option behind the front fender.
I could go into more detain if you would like, however it gets technical (my graduate studies were on the design and optimisation of a heat exchanger core for a radiator)
Plazmaman is correct in saying that powercoating and even painting to a lesser extend is an insulator. Because these have typically orders of magnitude less conductivity than aluminium and the extended conduction distance between the base surface of the fin and ambient air you get less fin efficiency.
Hope this helps everyone.
HI guys interesting thread.
The paint that radiator places use is a matt black. The reason they use the matt paint is because your intercooler, radiator condensor etc etc are all cooled by the air that flows through them, matt finish has (when viewed closely) a rippled/bumpy (can't think of better words) finish which in turn creates more surface area (when compared to gloss) which in turn futher aids cooling of the given substance.
Black, however, attracts the heat where as White deflects it.
If you are going to have a front mount you want want the majority of the heat exchanger seeing as much cool air as it can, its no use having a front mount thats obscured by bumper, number plate etc etc so if you're a cop and see a gaping hole in the front of the car and you know what you're talking about its going to be obvious that its there, but I will agree that a black one is harder to see.
I installed my front mount with a fly screen covering it to prevent bugs and road matter from clogging the fins. Its very visable, I'd like stealth but can't be assed doing all that work. For show or For go i guess.
I guess the only way to find out which is best is to do some testing and I bet many people (myself included) actually measure the before and after effect there new cooler has on intake charge temp! So really
to find out exactly whats best we all know what needs to be done, but i'm lazy so I'll let someone else do it cheers people
In the words of Forrest Gump... "thats all I have to say about that".
Hey guys, I finally got a chance to pick up my FMIC kit from the anodizers. And here is the result:
Note: The white-ish stuff on the core is only residue and will come of with light brushing or when driving.
Im really pleased with the result and cant wait to get it fitted next saturday...
Cheers
  • 1 month later...
-3 Cans of Flat Black Spray paint for core + piping
-I've also got a mesh which is sprayed black in front of it
-Black Silicon reducers from Justjap
-Masked up the fins of the core, concentrated on the endtanks and tube between the fins, took off the masking tape and did 1 light layer over the fins afterwards.
  • 3 months later...
Cheers
hey man - you got pics of it installed??
    • Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything?? but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
