Hiya all,
just got a quick question regarding my R33 Series 1 Auto. I'm looking to replace the ECU (mainly so I can get it reprogrammed for 96 octane and new turbo) but am concerned that it either won't communicate properly with the current auto computer or won't work at all in conjunction.
As such, I'm wondering if anyone can recommend a good duo system, or auto computer that will work with like a Wolf, Blitz or FC ecu...or hell, even just a supplier since google can't seem to help me out with any combo of search terms I am trying.
Thanks in advance.
https://www.sau.com.au/forums/topic/148649-auto-computer/
mate just a quick reply on your ecu.. why remap it if it's already comes from japan standered tuning for above 100octane fuel.. japans premium is rated at 102octain .. so dont stuff around with it i recon .. the only thing i would sugest is running a after market ecu like i have for max tuning .. i have a microtech LT12 bigggy baked.. runs well since mine is all stock .. on 10lbs it's doing 180rwkw..and mine is a auto to.. Bill
https://www.sau.com.au/forums/topic/148649-auto-computer/#findComment-2773505
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
    • Pay diff/trans workshop to do this.   Nope. Z32 turbo ran R230 with 6 bolt GTR style axles. All other Z32 were R200. Basically same same as other R32 stuff. All were a viscous waste of space.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
