Hey there,
Some of you may know I have a problem with my R33 at the moment, seems as though it is missing, anyhow thanks to help of people here they said either the Spark Plugs, ECU or Fuel Filter would be my problem.
Now I'm just in the process of taking the Spark Plugs out to check them, now I just want to make sure I've got the right plugs here.
They say on them:
NGK
R
PFR5G
11
Edited by GTS793
https://www.sau.com.au/forums/topic/148652-spark-plugs/
Yeah, they are irridium plugs and apparently RB's don't like them too much.
Car only has the following mods:
- K & N Pod Filter
- Cold Air Intake
- Forged Pistons
- Strengthen Conrods
- Blueprinted
- Balanced
- Port Polished
- Metal Head gasket
- Spitfire Coils
- High Performance Timing Belt
- High Performance Spark Plugs
- Gready Turbo Timer
Everything else is stock, stock ECU, stock boost etc.
https://www.sau.com.au/forums/topic/148652-spark-plugs/#findComment-2773406
Use these plugs I have never had a problem
with them and so has many other R33's
In regards to your previous thread,
concerning your missing issue.
I would check your coil packs for fine hair-line
cracks, which release the current as they heat-up.
Resulting in an insignificant spark that does not
ignite the combustion chamber(s) properly.
Merry Christmass
Hope this helps,
Cheers,
Bill
Edited by Nabil
https://www.sau.com.au/forums/topic/148652-spark-plugs/#findComment-2773415
Hey there,
They say on them:
NGK
R
PFR5G
11
Is the number 11 the heat range? If so, is that right? What should it be?
https://www.sau.com.au/forums/topic/148652-spark-plugs/#findComment-2773444
Everyone is telling me different plugs, I don't know what ones to buy tomorrow ..don't want to trust Autobarn either.
I've been told use:
BKR6E Gapped at 0.78 or BCPR7ES
Not trusting them is like saying you dont trust the NGK listing, which is fairly good considering NGK make genuine Nissan plugs.
They will list Platinum plugs for your car. Highly doubt they will have BCPR7ES on shelf tho.
https://www.sau.com.au/forums/topic/148652-spark-plugs/#findComment-2773449
As you already have splitfires it eliminates coil problems as you have stated.
There's nothing wrong with the plugs you have in there now for the turbo and boost you are running. Gapping them down at stockish boost levels is pointless, it's usually just a mask for dud coils.
I suspect your problem lies with the stock ecu running into rich and retard, which in turn introduces a rich miss. A colder plug as recommended above will make the problem worse as it is more sensitive to over fueling and fouling, particularly at lower plug gaps.
As a first move, gap your existing plugs down to .9 or so and see what happens. Then get the car to a dyno for a power run and see what the mixtures are like, while it's there get the fuel pressure checked at the rail to see if your pump or fuel filter is dead/dying.
Just for reference, i run splitfires, 20psi and 7 heat range plugs at .9 gap with no miss/fouling issues.
good luck!
edit; looks like you posted while i was writing. congrats on the find. almost certainly the problem. Just so you know, plugs don't just burn off electrodes for no reason....
Edited by BHDave
https://www.sau.com.au/forums/topic/148652-spark-plugs/#findComment-2773468
Id be more worried now what damage the pissing part of the plug did to the cylinder, the piston, and possiably more parts of the engine.
Thats what I am worried about now, esp after I forked out 6G's for a Forged rebuild.
What would have caused the plug to do this? It was only 1-2mts old.
https://www.sau.com.au/forums/topic/148652-spark-plugs/#findComment-2773472
Yeah, thanks for writing all that up though.
Now I need to find out why the plug did that and why, it is wierd I've never heard of it happing before. Anyone know what I should do now - anything I need to check before putting in a set of new plugs?
https://www.sau.com.au/forums/topic/148652-spark-plugs/#findComment-2773473
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
