Hi guys,
heller44: I bought the HID Kit in a group buy started by nismos15. Because I haven't gone on the road with the new lights (my car has a leaking brake system), I'm not too sure how well it performs on the road. The kit is alot brighter than standard lights and the cut off line is more clearer with the HID globes.
SoFly: The H3 globes were a straight bolt on to the H3C socket. It took me less than 10 minutes to test the kit and that was in the dark with a torch :( . All I had to do after that was mount the ballasts.
before conversion cutoff line
before conversion front view
during conversion front view
after conversion cutoff line
after conversion front view
They're not the best pictures but you get the idea.
Cheers
Adam
Edited by adam-__-
https://www.sau.com.au/forums/topic/148663-hid-for-r32/#findComment-2778040
hanyou: Nah I don't mate.
When you look in the engine bay, you don't notice anything different from stock. I tucked all the ballast and cable away so you don't really see them.
I still need to adjust the light angle and see how they go on the road. Just have to wait till I get my parts.
Cheers
Adam
https://www.sau.com.au/forums/topic/148663-hid-for-r32/#findComment-2781069
  • 3 weeks later...
You can use H3 or H3C, the only difference is the ground wire. I've got a pick somewhere where I added a ground wire - it's pretty easy. In my experience the hotspots and glaring is terrible with xenon kits. I'd only use them on projectors. a31, r32 and s13 projectors seem to work fine with no leaks, minimal no glare, excellent cutoff and minimal hotspots...
https://www.sau.com.au/forums/topic/148663-hid-for-r32/#findComment-2835817
My car originally took H3C's but I got an H3 HID kit and there was no modifying needed. I think you only have to add a ground wire if you were to keep the halogen globes.
Cheers
https://www.sau.com.au/forums/topic/148663-hid-for-r32/#findComment-2837074
  • 1 month later...
Has anyone installed a HID kit on an R33 GTST?
Is it as easy as an R32 install? R33s use H1 bulbs
Adam, is the cutoff line able to be adjusted to be higher or lower?
I don't want to be blinding people if I install it on mine
Hey mate, you can adjust where your lights are pointing the same way as you would with the halogen globes. I pointed my lights down more than normal because as you can see, there is more glare and I don't want to be blinding people more then I already am.
Cheers
https://www.sau.com.au/forums/topic/148663-hid-for-r32/#findComment-2972398
  • 8 months later...
i had a r32 gtst and it use H1, not using H3, and i can't manage the fit the HID bulb in, because the stock H1 are plug into a cap, and you twist that cap into the headligh housing, so it don't comes with any metal spring that to holding the bulb like the GTR, and the H1 hid bulb is impossible to plug into the stock holding cap without modification... so anyone done this before?
https://www.sau.com.au/forums/topic/148663-hid-for-r32/#findComment-3483308
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
