Hey people, anyone with any ideas on this topic would help.. im driving an r33 gtst with a trust fmic and forward facing plenum chamber and a greddy emanage which are the main mods... stock turbo, recently had it on a dyno to find it had 139.9 rwkw... which is kinda a swift kick in the nuts since its running 12psi... the ignition coils are fine.. air/fuel is good.. exhaust is a 3" front pipe to a 2 X 2.5 cat back system. fuel pump is a walbro pump of around about 500hp... when you drive it you put your foot down and it just doesnt really go anywhere like it should, i seriously think i could run quicker... but theres no missfire or anything.. just no power. theres a broken knock sensor snapped off in the block but i've been told the emanage bypasses that (hence why i baught it) and i beleive it has... any idea whatelse to look at as too why im about 40/50 rwkw shy of what i should be?? only thing i can think of is maybe the timing..
https://www.sau.com.au/forums/topic/148675-less-power-then-stock/
I had my car on the dyno the other day, and knew previously it had run 185kw. The dyno showed 140kw, and the dyno operator was saying 'wow, thats a good result'. He was clueless and thought it was an RB20, not RB25.
Anyway, my timing ended up being WAY out, and that was causing power problems. was -4 deg (retarded), and we moved this to -12 deg to run 195kw.
I wonder if timing could be your problem?
After the comp test, i would look @ the tune and parts that have been fitted
There are other things like the plenum etc that could be the issue... as most of the stock parts easily get you into the mid 200's
Exhaust might be restrictive aswell or the cat has collapsed.
There are lots of options
comp test X3
timing belt/cam timing
check all sensors are working except the ones u dont need like knock etc (could just have an electrical gremlin somehwere)
tuning - where did you get it done? take it t a reputable tuner
what dyno/how was it run?
Edited by VB-
when i first got mine I ran it up on stock turbo @ 10psi, FMIC, 3" cat back zorst and Emanage I ran 180rwkw...The plenum probably wont add much with ur power levels..
Should should be the same if not better than that result.
Thanks for all the advice fellas. im taking it over to melbourne now in the middle of feb for someone to look at.. no mechanics down here would have half of a clue what to look for... cant think of the name of the place im going too off the top of my head but i have one of the head fellas of autobarn in melbourne helping me so hopefully it can be fixed just by tweaking something on the dyno. if i had a light i'd check the timing myself but i cant really be bothered at the moment... once again, thanks for your input
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
