Best Cars For Drifting?
Hay guys how are ya? iam a skyline lover but dont own one yet
iam planning on buying an mr2 and every person in the world says to me if u try and drift one of those ur crazy heheh
but thats the car i want =) not to sure about the drifiting in it
i love drifiting and have tried it afew times being unsucessful and learning a big lesson =)
I just wanted to know what you guys reconmend as
in good cars for drifting?
and the good points and bad points they have?
Thanks =)
Guest veesixtyfour
IMHO, The best drift cars ive seen are s13 (180sx/silvia's or sileighty's *drool*)
and of course the good old skylines :P
Matty
:burnout:
hey draggo what big lesson did you learn? good to see you again man.
s13's are great for drifting. Utes are good too. Hell my cars not bad but there is too much weight.
P.S. Get an S13 you clown :P
Guest veesixtyfour
Throws it all out of wack? lol :lol:
The idea of a mid engine is keep the center of gravity... in the center of the car.. exactly opposite of what drifting is... :uh-huh:
MR2 = BAD news for a driftin' car, Awesome for handling though :mad:
Guest MattY
I used to own a 95 mr2, in fact i went to a track day at wakefield with a few sdu ppl.
Orite for handling, not so good for drift although it is oh so possible. Its just not very progressive and yes you need to be really really quick on the wheel. I was practicing some drift in a hugge ass car park, and everytime the thing bit me in the ass i slammed my hands agains the window sill or door n stuff....
I now have an s15 and its much easier to handle in all respects.
the only think i would recommend the mr2 for is the fact that theyre hell good to launch and they look sweet with the targa down : )
hope it helps.
squizz, i NEED to have a rear seat, i always have at least 3 passengers remember. i did take the spare/hydraulic jack out the last 2 times, but this time i will leave them in.
 Share
    • Well I had 2 choices from then on. I either had to (reluctantly) move it on to another potential buyer and take the loss on the chin. Or I stick with it and turn it into a restoration project. I chose the latter. Project Snowstorm began! The frp body kit was the first thing to go. Turns out the original colour used to be silver. The Neo and gearbox were removed, along with the prop and exhaust system before it took a trip to the bodyshop, where I wouldn’t see it again for quite some time due to the pandemic hitting very soon after they took it away. Eventually, progress began and damage assessments made. Even the front chassis leg was in pretty bad shape!     Then the chopping commenced. For these guys it was just usual routine, to me it looked absolutely terrifying!   More to follow as I’m struggling to focus on my screen at 12:45 am!!!
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
