I am offering for sale my 180SX.
S13 180SX 1990
Green compliance plate
1 owner since import 6 odd years ago
Engine/Powertrain
RB25DET R34 NEO
Lots of polishing, painting & detailling
Nismo 555cc (pink) injectors
Custom Fuel Rail with twin feed
Turbonetics T60 turbo (polished cover)
HKS50mm wastegate
Custom stainless thickwall mainfold plus 2" screamer
Autronic SM4 management system including boost control, launch control, ignition multiplexer etc
Turbosmart V port BOV in custom red anodise
Custom inlet plenum with tapered tube runners, bellmouths and optimised volume (as per Borneo's Ceffy - we made 2)
Nissan Infinity Throttle Body
600x300x75 intercooler with polished piping and silicone hose (genuine early Hybrid)
Apex N1 exhaust, full polished stainless cat back
Custom 3.5 inch stainless front pipe & Cat replacement
Huge K&N Pod (6inch stainless funnel to turbo)
Catch can with drain-back
Loads of Speedflow stuff
Custom radiator
Remote radiator filler/header tank
High flow thermo fans (SPAL x3) and ductwork
Bosch Motorsport fuel pump, in tank
Sard Adjustable Fuel Pressure Regulator
RB25 5 speed box (the big one!!)
Custom Tailshaft
Extreme XHD clutch with 9 puck ceramic disc and explosion proof cover
Aluminium flywheel
New Clutch Master & Slave cylinders
Mech LSD with 4.3 gearing
Power steering cooler
New Water Pump
New Timing Belt
Engine relocated lower and further back than ‘typical’ – approx 25mm rearward for improved weight distribution and good shifter positioning.
Suspension/Steering
Whiteline sway bars
Whiteline poly bushes throughout including pineapples
JIC radius rods
D2 Racing Sports D1 Spec Adjustable Coil-overs
Hicas removed (runs a lock bar)
Carbon fibre front and rear strut braces
R33 steering rack & Pump
5-stud conversion using S15 parts (mostly new!)
Brakes
R32 GTR 4 piston front calipers with DBA4000 series 324x30 R34 GTR rotors (using professionally made dogbones)
R32 GTR 2 piston rear calipers with 300x18 rotors
R32 GTR master cylinder (compatible with factory abs)
R32 GTR Internal drum handbrake
Braided rear brake lines
Nissan genuine pads
Factory ABS
Wheels/Tyres
18” ‘Volk Evo4 forged lightweight’ wheels (8's front, 9's rear)
235/40 rubber up front and 265/35 down back (not much tread there!!)
Interior
S15 front seats
Factory head up display (still works!)
Tacho recalibrated to display correct RPM for 6 cylinder
Kenwood CD tuner
Rockford Fosgate front speakers, in stock location
Pioneer rear speakers, in stock location
Tint
Alarm with locking & battery back-up siren
Late S13 SR digital climate controller
Greddy Electronic Boost, Oil Temp, Water Temp & Exhaust Temp Gauges
Greddy single gauge A pillar pod
Mudd Sports 3 gauge on dash pod
Air cond has been removed
Body
Custom Red pearl paint with 'House of Kolor' Rainbow 5 colour flake
Origin Type 2 Carbon Fibre Bonnet (this is HORN!!!)
Genuine Wise Sports front bumper, modified and ducted
Genuine Nismo side skirts
Genuine Nissan rear mud flaps
Nissan Type-X rear wing (late model 180SX)
Clear front and side indicators
Factory Sunroof (with new seal)
Uprated headlight globes
General
Price is A$25,000.
This is a comprehensive no-shortcut long time build. Anyone who has seen the car will confirm this.
Has been a magazine feature car (long time ago - dont ask me when) and will have another feature completed shortly.
Was used by Adelaide Clutch for their display at Auto Salon earlier this year.
Car is not used at all and needs to go.
Some pics following. More info etc to genuine interested parties.
Call me on 0418822444
Glenn Campbell (aka Lumpy)
Edited by LUMPY
https://www.sau.com.au/forums/topic/148721-lumpys-180sx-rb25neo/
Bump for one of the old school of Aussie S13 import owners from way back from another old crusty bastard.
I'm sort of hoping youre at least going to buy an S15 with the funds from this baby :)
Thanks! Yep, getting crustier by the minute!
There is an S15 in the stable now - being built for DA next year.
  • 5 months later...
  • 2 months later...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
