Not necessarily doubting you Mark but auto diffs are usually longer. In the R34 the auto is 4.089 and the manual is 4.111. I know that's close enough to be almost the same but you see whatI mean?
I thought the R33 auto diffs were 3.9xx but I've got nothing to back myself up there. :cheers:
From what I understand the auto R33 diff is a 4.3 and the r33 manual diff a 4.1.
The R32 Turbo's run the same diff ratio for both the auto and manual being a 4.3.
Abobob, The reason for the r34 ratio being different may be due to the gearbox ratio's. The R32/R33 auto's run quite a long first gear. If they were to run a 4.11 ratio behind the auto they would be looking at almost 70km/h out of first.
I thought the R33 auto diffs were 3.9xx but I've got nothing to back myself up there. :happy:
In older cars when you had top gears with 1 to 1 in both manual and autos, autos always had lower ratio diffs ( lower number but actualy higher diff, longer legs). The reason for that, the torque converter in the auto slips so it makes easier to take off and because it slips lower high speed .
Most late model cars don't use a straight gear anymore and most autos have a very high top gear ( around .7-.8 to one, even lower) . Thats the reason you don't need a higher diff in autos now so it wouldn't surprise me if the auto was the same as a manual. These days most cars have a lock up converter in top gear ( even top 2 some of them with 5 or more ratios) .I have no idea what the skyline ratios are though.
Edited by wrxhoon
On that note I have a rear diff ratio of 4.375 thats in good nick if any one wants it? >_<
I bought a GTR diff that already had the swap done to it. Its in excellent condition but I'm keeping the centre and half shafts. I'm selling just the diff gears (pinion and crown) or the pumpkin if the individual wishes not to stuff around refitting the pinion to their pumpkin.
I was hoping for a set of 4.11's to go behind the rb30. Bugger. :)
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
