Eh, I was going to keep it, but I would never install it.. so, someone else may as well scare small children!
As the subject states, for sale is a Turbosmart Vee-port blow off valve. Looks pretty. Look, picture!
Comes with an adapter to fit onto VR4/evo pipework.. so, it should fit GTST pipes no worries.
They're 300 bucks new.. I'd be happy with 100 bucks. Or, if anyone plays guitar, I will trade for a decent quality volume pedal (Morley, Ernie Ball etc).
Y r u Selling it??
Does this fit on StraightAway?? I have a R33 GTS-T with the Stock BOV still Installed..
Will i need an Adaptor..??? What is this Plumback thing about...
Cheers..
P.S.( I'm in WA so i can Pick it Up)
I'm selling it as it is unfortunately incompatible with my piping kit. Basically, it hits my shifter cable.
It is not plumb-back. A plumb back BOV is one that vents back into the intake system. This particular blow off valve vents air direct to atmosphere, and makes a quite loud "psssh" noise. Great for scaring small dogs.
Anyway, as far as I'm aware, it will bolt straight on to a skyline, you guys basically have the same flange and even the same BOV as evos/VR4's. Someone will no doubt correct me if I am wrong. Just unbolt the stocky, put some sealant on the gasket, bolt it on. Connect vacuum hose. Additionally, you would have to block off the part where your stock BOV reconnects to your intake (not hard, just find a rubber bung or something like that, hose clamp it on nice and tight).
And finally.. and someone will probably have to talk you through this.. I think using an atmo BOV such as this one creates problems with skylines, as there are issues with unmetered air.
I am in SA, I have no problems posting it though. Will probably cost 15 bucks or so (it's sort of heavy).
Edit: Just did a search, the unmetered air thing is just if you don't plug the plumb-back hole up (obvious).
Also, the other problem is stalling due to weak springs in the BOV allowing it to open when it's not meant to. This thing is practically new, and the spring is adjustable, so if you have a stalling issue, just tighten the spring.
Hope this helps
Edited by doommachine
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
