Hey,
I own a r32 gts25..sometimes when i turn the key to start it the engine sometimes kinda jitters..or i'll turn the key and the starter motor will just be going but the engine does not start..but at times it will start first go..it's weird..i've been told it could have something to do with fuel injectors..?
Also my car has hicas..the last month or so when i start the car for the first time of the day the hicas light stays on for like 2mins of driving then goes off..it will also go off if i floor it sometimes to..steering feels fine..but it does shutter over 70kph even after wheel alignment..but that was a while ago..
Anyways if anyone could help that would be sweet.
cheers.
https://www.sau.com.au/forums/topic/148781-starting-probs-and-hicas-question/
You have to be more specific with your details, when you say you hear the starter going and the car wont start - is the engine cranking or can you only here the starter spinning? Starters have a little clutch in the front of them that over time wears and will slip from time to time.
If its fuel related, only thing I can think of is if the fuel pressure isnt right? Before starting it let it prime a couple of times before you start it and see if that makes a difference.
Cheers
Sumo
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
