Hey,
I own a r32 gts25..sometimes when i turn the key to start it the engine sometimes kinda jitters..or i'll turn the key and the starter motor will just be going but the engine does not start..but at times it will start first go..it's weird..i've been told it could have something to do with fuel injectors..?
Also my car has hicas..the last month or so when i start the car for the first time of the day the hicas light stays on for like 2mins of driving then goes off..it will also go off if i floor it sometimes to..steering feels fine..but it does shutter over 70kph even after wheel alignment..but that was a while ago..
Anyways if anyone could help that would be sweet.
cheers.
https://www.sau.com.au/forums/topic/148781-starting-probs-and-hicas-question/
You have to be more specific with your details, when you say you hear the starter going and the car wont start - is the engine cranking or can you only here the starter spinning? Starters have a little clutch in the front of them that over time wears and will slip from time to time.
If its fuel related, only thing I can think of is if the fuel pressure isnt right? Before starting it let it prime a couple of times before you start it and see if that makes a difference.
Cheers
Sumo
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
