Hey guys,
Currently im building a 180sx with an RB25DET in it and just need a few tips/pointers as to the turbo setup i should run. I have searched and so far the most tempting turbo I can find is a HKS 3037S 52T .87. My goals for the car:
- 350-400rwhp
- Step 1 cams
- Headgasket (8.5 CR)
- Supporting fuel system
- PowerFC
- Stock bottom end
- Used for drift events/street
Can anyone suggest a better turbo for my project? If so, what and why is it better? :nyaanyaa:
Also just need some educated guesses as to when the 3037 .87 will make full boost (lets say 17psi) and what sort of power I can expect from this boost on a good condition RB25.
Thanks heaps,
Ryan.
https://www.sau.com.au/forums/topic/148794-choosing-a-turbo/
im running a HKS GT 2835 PRO S, full boost by 3300rpm (16psi) max power 337rwhp (very very rich tune 11:1 afr)
running stock engine (only got 740cc injectors and z32 afm + pfc) and my engine got 125,000km +
Both the gt 2835 pros and GT-RS make similar power and come on boost hard and fast;
I use to do abit of drifting and found the 2835 to be awsome comes on boost very fast and once it was going i never saw much lag at all and even at 337hp it was enough to get the r33 sideways :nyaanyaa:
Good luck :laugh:
52 trim 3037 would be my choice as well but step down to the .63 exhaust.
I'd also leave the stock head gasket alone.
Check this thread out for a garrett alternative using a 52 trim wheel (garrett only offers 56 trim normally). Cost should be significantly lower than the HKS.
http://www.skylinesaustralia.com/forums/in...howtopic=147580
' date='27 Dec 2006, 02:38 AM' post='2775209']
Thats some good power. Out of interest, when "Pro" is used in conjunction with HKS turbos does it generally just mean they are internally gated or are there some other important differences?
Im coming from a CA18DET so i just assume changing the head gasket is a necessity for running high boost :P....is it not that necessary with RB25DETs? Also, the reason im after the .87 A/R is mainly so that there is room for expansion later in case I want to go higher (lets say i break my engine then get it built). I saw a thread somewhere on here where someone was making about 400rwhp but on the .63 version and he actually said he preferred the .87 as the .63 was to responsive (i like that nothing, nothing, BAM! feeling). As long as full boost is before 4k I would be happy.
Edited by rinmak
not sure :/
the turbo is great, with a retune (11:1afr at the moment) im hoping for around 350rwhp @ 16psi, looking to drop some tomie pon-cams and headgasket in the future and see what is makes around the 18-20psi mark hopfully high 300hp
Garrett makes no sense to me.. :/
Is this a GT30R?
http://www.horsepowerinabox.com/HPIAB2/prod18.htm
Would you suggest the .82 exhaust housing? Its alot cheaper than a HKS item which makes it tempting. Are there any major differences between them or are you just paying for the badge with the HKS one?
Edited by rinmak
my tuner made 404rwhp @ 1.38 bar with it...dyno in rb25 results thread........i wanted the pro s tuner said wait for gtrs..
that is very impressive from a GTRS..
265rwkw @ 15psi, modest tune due to standard internals, with 2835 pro s...
extremely happy with lag, drivability, power delivery..
Any comments on this turbo guys? Is this the GT30R Slide mentioned earlier?
Its a fair bit cheaper than the HKS 3037S so if it can do the same job that would be awesome. Would you guys recommend this turbo in .82 for a 350-400rwhp 25?
HUh??? maybe cuz its new and not many people have wacked big cams in with em etc etc...or the tune is safe.....cuz with just the turbo i only made 250....theres a 1st time for evrything.
Maybe, i'd like to see at least one other car make 300rwkw/20psi though.
The Rb25 turbo upgrade thread in forced induction shows a few results with this turbo.
Its quite common to see 265-275rwkw at 16-17 psi
Power just seems to hit you when you want it whilst drifting i have found.
The GT30R (GT3076) is not the same turbo as the 3037s listed in the link above.
It is rated to the same power how ever has a .70a/r compressor cover usually found on the GT3040 etc rather then the .60 on the GT30R.
Yes I agree , I've never yet seen a real GT3076R with a .70 A/R compressor housing . You could nearly bet that thing is either a GT3040R (GT3082R) or one of the victim grade GT30+ TO4S compressor wheeled horrors .
With the real GT3076R's (cartridge wise same as HKS's GT3037's) the power rating is claimed to be 450 and 480 PS for the 52 and 56 trim compressors in Garretts TO4E .60 A/R port shrouded compressor housing .
Cheers A .
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
