Super Comfy Gtr Suspension
Hi Guys, I am looking to do something a little bit different with my R33 GTR and change the suspension to be extremely comfortable since I drive on some of the crappiest roads QLD has to offer. It currently has Bilstein shocks and lowered king springs and 18x10 rims. This setup has been pretty good but the dash just rattles away on the bad roads and the car bounces around a fair bit.
Does anyone know if it is even possible to get a suspension setup on a GTR that is as comfortable as say a Mazda 3 or BMW M3 or any of the modern European sports cars, yet still retain decent handling? Or does the rigid chassis and other factors make this impossible or unfeasible?
If so, does anyone know any good suspension specialists in the Brisbane area? (Not too keen on Pedders or Fulcrum)
Thanks
Thanks
Why not have a chat to Fulcrum Suspension? They have the Tein super Street and may be able to soften the spring rate a little.
Maybe try dropping back to a 17" rim, which will introduce some ride comfort via sidewall flex.
The Mazda is not a performance car, so will not have performance car suspension. The BMW, while a sort of performance car, is still fitted with family-car-comfort suspension.
If you want a comfy ride, get a Falcodore or something. If you want a performance car, put up with performance car ride and comfort.
Yeah you'll find a smaller rim with more sidewall will help take off some of the edge on the bumps....
If you know someone with stock GTR suspension maybe you should go for a ride in that and see what you think....
hi I live on the sun shine coast and have just fitted front bilsteins with standard springs still have standard gtr at back Im really impressed with the ride improvment ( took of some jap street damper) mabye some standard springs may be the answer
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
