I had may car at the mechanics late last week for a remap to suit the new turbo combo, much to my dissapointment there wasnt a whole lot of improvment in max power.
The current set up is an emanage ultimate, gt30/vg30, with a blitz sbc controlling boost.
While i am quite happy with the way the car drives i would still like to squeeze a little more out of it.
The suporting mods ive been told should see me around the 200 awkw mark, but the best so far was
176 on boost setting 4, 1.1 bar.
my problem is this, beyond this level, vehicle boost cuts. the mechanics have scoped and data logged to determine injector and air flow meter ranges but neither were the cause of boost cut, also inspected for boost sensing devices for factory ecu, none were evident.
They seem to think that the internal mapping of the factory ecu offers fuel cut at certain rpm when boost causes specific injector demand.
has any one else had this problem I know there are a quite a few s1 out there that have 200awk and above,
any ideas or advice would be appreciated.
https://www.sau.com.au/forums/topic/148814-not-quite-there-yet/
yeah id also like to know as i cant adjust my boost at all without the boost cut ... 100% factory boost spec with the annoying dual stage boost control. I tried doing the boost solenoid trick and it jus hit the boost cut (can run it standard tho and no probs??? weird)
So now i have a hi flow turbo and im back to fully stock boost ... feels tha same as a stock turbo runnin about 11-12 pounds ... very annoying especially when i got smoked badly by someone on this forum the other day when they werent even in a Nissan :pirate: you know who u are!! :laugh:
cmon guys an girls any help??
Lee
again,people keep denying the boost cut exists,when it does. rich and retard does NOT put your head through the windscreen in the same way the boost cut does.
1.1bar is just over a kg/cm2,which is where my series 2 oes the same thing - it CUTS the ignition. it doesn't retard it a few degrees,it stops it.
a retard gives you a dull feeling,a cut stops the party entirely,which is what happens. again,do people want a demo? I'm still happy to be proven wrong in person on this.
Justin...
I think the series 2 does monitor the boost at the ECU but the series 1 doesn't. They both run an R34 style of ECU but the series 1 is the only one to run the older RB25DET with this ECU. This means a few changes such as no facility for oil temp monitoring etc. I would follow wolverines advice.
Justin...
had mine on the dyno by a well respected tuner in Perth and he was the one that said it was the boost cut. confusing :P
Justin...
Yup, I know exactly what you are feeling there. With the SAFC and SITC you can tune around these, use a Z32 air flow meter too for better resolution for the tune. Make sure you have a good fuel pump and maybe a nismo fuel reg, then get it tuned on the dyno. Obviously a good exhaust & cool air supply is a necessity.
You'll get around that BAM into the windscreen feeling :(
Ive got that problem now, had everything tuned nicely with the stnd turbo but with the highflow now on, winding the boost to 14psi results in "head-2-windscreen" sydrome - as you describe, its like the ecu just shuts up shop, a feeling very similar to when you hit the revlimiter in 4th gear on a sportsbike = over the front you go!
ggrrr need a retune! need funds lol :happy:
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
