...in my opinion there is less piping with a return feed cooler than there is with the other type
I reckon you would be covering the same distance, just by a different route: One under the motor, the other over the motor. There would be bugger all difference in it lengthwise, unless your inlet and outlet are on the same side of the IC. At the end of the day, what is more important, and has more effect, is the pressure drop across the core of the IC.
Just for the technically minded: I believe the pressure drop due to one 90 deg bend in the pipework is equal to the pressure drop over 3 metres of straight pipe. So the second most important thing (after pressure drop across the IC core) is to reduce the number of bends.
  • Replies 45
Observations on Mike's Pics:
Noice work in all, not sure if cutting the big chunk out of the metal part of the front bar did anything other then weaken the bar, as you probably would have realised when you put the plastic bumper back on - it covered all your ventilation anyhow.
What can be helpful (slightly) is to put a strip of foam across the top edge of the IC between it and the bumper bar, this forces the air coming in to go through the IC rather then up and over the top - you will see this same idea used by the factory on the radiators.
Also noticed that the outlet pipe (drivers side) from the IC goes further out before making the bend towards the back of the car. I see the black plastic strip being pushed out of shape by the pipe, whereas the (passenger side) inlet pipe is barely noticeable from the front. Personally, I just cut both of the plastic strips off.
You could try cutting a couple of inches off the pipe then reinserting it into the blue connecting hose to make them look even. NB: flare the end of the pipe after you cut it or it will pop off under boost. Secondly, dont be lazy and remove the pipe completely if you intend to cut it or filings will make their into the motor.
Actually, I just realised, if you pull the pipe off you may notice that the lengths of each end are different - one is shorter then the other, so you may simply have it in upside down. Depends on your kit though.
Edited by 3intheBack
One final thought for you all:
Now that you have added about a dozen extra 8mm nuts to your car, or even you if you are contemplating doing this, then go and buy one of those flexi drives for doing up hose clamps and store it in your car tool bag.
If you ever pop a pipe off out on the road it will be next to impossible to get them back on and tightened up with just an 8mm spanner.
Which brings me to my next point - test the tightness of your clamps, by double checking everyone by hand firstly, then by getting out on a double lane highway and flooring it for a number of seconds, so as to maintain full boost for as long as legally possible. If a pipe pops while overtaking a car, then you will lose all power, in fact, it probably wont even idle.
  • 1 month later...
Hey all
Just to dig up and old thread I finally did my FMIC install yesterday. I used one of the GKTech kits. Was pretty easy to fit. Had to remove a little from the front bar support (but only a little and it can't even be seen) but all the brackets fitted perfectly. Pipe work was also easy and just had to cut a hole under the battery tray (which also killed my drill in the end :D ) I did how ever run into problems with the washer bottle. There was no way it was going back to the standard location but after looking at one of the pics in this thread I know I can just spin it 90 degrees and make a new bracket so that will be easy, but i'm going to wait till the body kit is fitted as I can't be stuffed pulling the front bar off again just to do it again when the kit is fitted. All in all it only took about 5hrs total. The only complaints I've got about the kit is the clamps that were supplied were pretty average to say the best and I will be replacing them with descent tbolt style asap as they can't be tightened to much with out stripping. But apart from that its a great kit and for less than $400 delivered then I really can't complain :O
Not really getting stuff all air flow atm but my nismo kit is getting fitted in a few weeks so will have MUCH more then and should look good.
post-26232-1175514719.jpg post-26232-1175479863.jpg post-26232-1175479770.jpg post-26232-1175479685.jpg post-26232-1175514632.jpg
Edited by Mr_RS4
I couldn't help but notice you have taken the "valley" cover off between the cams leaving the coils packs exposed - is there a reason for this? I was tossing up the idea of putting some slots in my cover for cooling purposes but I wasn't sure if this was a good idea. Is this why you have done it?
^^^ Yeah thats one reason why I did it but also (and probably mainly) it makes changing spark plugs so much easier. Plus I also like the look of it (don't know why :laugh: ) God look how dirty my engine bay is. Never used to be like that :laugh: But I'm going to start some color coding and detaling soon to match the new paint job.
Also I notice a lot of people cutting fan blades. A couple of guys at work just used these same kits on their skylines and got a work shop to fit them, and the work shop cut them too. I don't know why because all you need to do is make the hole under the battery a little longer ( to allow for more pipe movement back towards the firewall direction) and then drill another hole the in bracket on the top pipe that goes over the radiator about 10mm from the last hole and bingo no where near the fan. And I also needed to shave some plastic of the body of the A/C thermo fan shroud as its a bloody close fit. But if your prepared to cut a massive chunk out of your front support bar then there is no need for this as you can mount it further forward. But i mounted it further back and lower so there is only about 5cm as the most of the cooler behind the front bar support.
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
