so after many year of waiting, i finally got my r33 gts-t last week. It had a really nice body kit as well as some performance mods and was in great nick. The owner warned me about driveways and just said be careful cause its low.
So after less than a week of driving, being super careful around driveways and speed bumps, i get back to work today after holidays (which has an undercover carpark). I drive into the drive way no problems and drive down the hill, open the gate then slowly creep down the hill thinking it should be ok. next thing i know, *crack*. front bar has copped a nasty knock. back out and take a look.. its a nasty-ish crack with some surrounding paint chipped of the front bar as well. I read the home-repair thread but i think this one might be a little out of my ability. Its not like the bar is hanging off or anything, but the crack is pretty bad and its chipped away a fair bit of the paint.
I checked the 'queensland workshops' thread but it only had 1 panel beater listed, and that was in brisbane. My questions are:
1) can any panel beater fix this up or does it need to be a bodykit specialist or something ?
2) what sort of price range am a looking at. Its going to need more than just a respray, some fibreglass will need to be replaced and stuff, but its not like they have to go over the whole bar fixing it.
3) anyone have any recommendations of places which will do a good job that are on the Gold Coast. the only one that someone has said to me so far is burliegh smash repairs with a warning that they do a good job but are a bit pricey.
Edited by Strik3r
https://www.sau.com.au/forums/topic/148824-my-first-crack/
that is too bad. i've had a fibreglass front bar for about 6 months now, scraped it on driveways, had a fury animal run out in front of me and all i have is 5 little cracks. the longest one about 3 inches.
any panel beater should be able to do it.
https://www.sau.com.au/forums/topic/148824-my-first-crack/#findComment-2775657
Pulled into a repair shop i saw while driving to get my stereo installed and got a quote for $250.. i'll check out a couple of others.. I'd take it to the recommended places, but by the time i drive there and back i'd be paying $30 in fuel so might as well get it done locally. Its not a horrendous crack, but it does detract from the look of the car. I'll play it a bit by ear.. i should probably wait another month or 2 until ive really gotten used to where I can and cant take the car before i get it fixed up, but then im pretty obsessive/compulsive about things being neat and tidy, so i dont know if ill put up with it for that long :P
thanks for the replies.
https://www.sau.com.au/forums/topic/148824-my-first-crack/#findComment-2777103
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
