I've got work Ewing's on mine... are thy the same as yours cause mine fit perfectly. I thought that were going to scrub something cronice before i lowered it, but independant suspention is a beautiful thing.. can't fit a finger between the tire and arch in the rear, sitting on custom Kings
GT-Ps are nice! I was looking at buying a set for my coupe back in the day, but they aren't cheap. My other choice was the Volk GT-U (mesh type) but they aren't available in 4x114.3.
All this trash talk about Watanabes is making me a bit iffy about buying a set of F8s from Japan, but I guess they're 100x more popular in Oz than here in NZ :woot: The last time I saw a set of 'em on any car would have been a good 18 months ago, and they were on some random 1980s Civic (go figure)...
Just out of interest what offset and width are you folks running on your R30s? The whole reason I'm getting the Watanabes shipped over is because the Work Ewing rims on my sedan seem to have the completely wrong values on the rear (15x8.0+24), and as a result they stick out from the guards by at least 20mm. Also, finding decent tyres to fit 15x8 rims proved to be the ultimate headache - I ended up stretching some 215s on, which was borderline when it came to warrant of fitness time.
Typical that I couldn't find any SSR reverse mesh rims when I was looking - now that the F8s are on their way, a whole slew of 15" SSRs have suddenly appeared on Yahoo Auctions Japan at bargain prices :O
https://www.sau.com.au/forums/topic/148828-my-dr/page/2/#findComment-2947788
    • On the compressor side it looks like the best, if your head setup will support doing 100-110lb/min at 30psi-ish boost.   The G45-1350 compressor looks ideally better if you need closer to 40psi for it, given both the G40 1150 and G42 1200 look like they'll be around the 100lb/min mark at 35psi and dropping from there.   Bear in mind the turbine sides are all different between those three turbos, so that COULD be an influencing factor for how they all perform in the real world as well.   Not sure if you've made a conscious decision to only look at Garrett or not, but at least on paper the XRE7169S matches or beats those other three at everything from 30psi up and just going from wheel size alone likely to be at least as responsive as the G40 1150 and seem to behave closer to G42s in terms of turbine flow.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
