Hi All,
Wondering if anyone has any ideas on this problem.
A couple of days ago i started my Series 1 R33 GTST and it sounded like it was running on 5 cylinders, I thought i had dropped a plug or coil. I pulled off the cover over the coil packs restarted the car and disconnected each coil pack to find the guilty party. I found number 4 was making no difference to the idle so thought i had located the criminal. I proceeded to swap out number 2 plug and coil to see if the problem then moved to number 2. alas problem stayed at number 4, I then swapped both number 1 plug and coil into number 4 and still the same problem, so I am convinced it is not a coil or plug issue.
I then drove the car cautiously as it vibrates at about 2000 revs and i went for 15 kilometres came out of shop and started the car and hey presto no chaff cutter, I drove it the 15 ks home no dramas all normal.
The next morning i satrted it and it dropped a cylinder again, drove it the 15 ks again restarted same problem went another 2 ks restarted and all was good again.
went to my sisters for xmas stayed 3 hours jumped back in car started no dramas drove all the way home with no problems.
Any Ideas
https://www.sau.com.au/forums/topic/148841-help-please/
it could be moisture in the wiring harness plug, or a short in the wiring harness, or the ignitor.
Thanks mate,
All was dry doesnt explain why even with 2 different plugs and coils it still goes back to number 4
https://www.sau.com.au/forums/topic/148841-help-please/#findComment-2775978
the times i have seen this before have had the following solutions- on my mates 180sx the plug on the injector for number 1 was faulty. on my mates r33 his ecu was fried (had a hole melted in it), but it kept frying number 6 coil.
if it was a sticking valve i think it would me a bit less intermittent. and it seems that when your car is warm it goes away.
https://www.sau.com.au/forums/topic/148841-help-please/#findComment-2776141
thanks for the ideas mate will have a look, by the way i ran a diagnostics on the ecu and got 55 all ok
https://www.sau.com.au/forums/topic/148841-help-please/#findComment-2776467
Hmmm could be injector related... id run a decent injector cleaner with a good batch of Shell V-Racing and down shift to 2nd while doing 60km/h going down a steep hill and let it roll while revs are up... that will open up ur injectors and clean out most crap... cause injector issues usually happen when they cold and sort them selfs out as the car warms up... happened exactly same to my SSS
Let us know how you go... Good luck
Regards,
Sarkis
https://www.sau.com.au/forums/topic/148841-help-please/#findComment-2776528
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
