http://63.240.161.99/motoroil/index.html
from other thread.
I just read the first page. I may have read it wrong, but almost seems as if it's very hard to go too thin, that's not that problem. Goes as thin as possible
from other thread.
I just read that link, and I agree. Thinner is better, for daily street use anyway.
I use fully synthethic in my RB25, and have since the day i got it
I Use Kendall full mineral oil in my R33. 20W50 in Summer and 10W40 in Winter. The stuff is absolutely fantastic. It basically stops engine wear and has the same if not better properties as synthetic oil including burn point.
Hey how are we all?? Just wondering I was speaking to a mechanic and was advised that full synthetic oil may be abit too thin for my R33 and for security has said that semi synthetic would be a safe choice. What do you guys think??
not true. oil thickness is not directly affected by whether it's synthetic or not. my advice is go for a good full synthetic. something in 10W40 should be fine. personally I like motul chrono 300V, but it's pretty pricey. there may be other options nearly as good, but for much less $$.
10W60 is not neccisarily a good choice. ideally you want the two weights as close together as possible. because to make an oil have the property of a 10 weight at one temp and a 60 weight at another requires a lot of additives. even a 10W40 has the hot weight 4 times the cold. 6 times is too much imo. 3 times or less is desirable. but I live with the 10W40 as it's a synthetic ester base.
Get a new mechanic, he has no clue about engines.
Beer Baron's rule of thumb is true for mineral oils at least, as they do have a natural tendency to thin out when hot, so additives are added to reduce this. The wider the vis range the more additives (which break down over time, meaning your vis changes).
Synthetic oils don't thin as much, and don't require as much additive.
Only go for a 50 or 60 weight when racing. It's much too thick for the street.
5W-30 or 0W-30 fully synthetic is perfect.
What are you guys thoughts on the fuchs (spelling??) fully synthetic 15w40 for a rb25det? ive used it in my old gtst rb20det and my current gts25t and never had any problems with it.
i use the Fuchs 10W-30 (full syn)
love it good stuff
i think for skylines you need a good full syn oil
RellikZephyr
Keep in mind guys, when the RB family of engines were designed in the 80's, synthetic oil wasn't terribly common. They were designed to use a 7.5W-30 mineral oil. Use this as a minimum and anything better will just be a bonus. I've tried the Nissan 7.5W-30 and it's pretty crap compared to pretty much all non-mineral oils.
With the numbers though, the first number (eg 5W) is the weight or viscosity of the oil - the higher the number, the thicker it is. Thicker oils offer greater protection but don't flow around your engine very well, which is where the second number comes in. The second number (eg 50) represents the amount of protection it offers - ie the protection of a 50W oil.
So the ideal situation is to have a thin oil that will flow easily to cover every component as quickly as possible, but have the highest protection.
You don't want to go too thin though like 0W which may actually drain down while sitting at the traffic lights quicker than your idling engine can get the oil up to the top.
I personally use Mobil 1 or Penzoil 5W-50 in my GTR. Probably not entirely neccesary, but I'm not taking any chances - I want the best for my baby :(
Edited by EVIL TWIN
Um, eh?
The first number (before the W) indicates the oil viscosity when cold.
The second number indicates its viscosity when hot.
So mobil 1 5W50 viscosity is 105 centistokes at 40 degrees C & 17.5 centistokes at 100 degrees C. 0W40 equivalent numbers are 80 & 14. The hot end is more important because you can cook the oil in a GT-R quite easilly with no cooler. This is why a higher viscosity hot temperature property can be a good thing.
These are physical properties of the oil & don't refer to it's protection. For that you need look at different API ratings for the oils. I don't know what "the amount of protection - ie the protection of a 50W oil." means.
Try the Mobil website....
http://www.mobil.com/Australia-English/LCW...c_V_Mineral.asp
you cant go wrong sticking to manifacturers specs when its a daily driven street car. For turbo piston engines, fully synthetic is better, because of the lower additives, and higher "cooking" point, which is needed when passing through the turbo.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
