hey guys, i got a problem and im a newbie with cars.. ok.. when i'm going straight about 70 kph my wheel slightly turns 2 the left, as i go faster my wheel turns more n more to the left. so u can imagine on the freeway doing 100kph my wheel will be turned left
then maybe about 15-20 mins of driving on the freeway the wheel will switch back 2 straight
if any1 knows wats wrong can u let me know how to fix it or where
oh yeh and its a r32 gts4
regards
kun
https://www.sau.com.au/forums/topic/148855-wierd-problem-with-steering/
Hey mate,
Was your hicas light on?
I have had a similar problem that went away after i turned the car off and back on. only ever happened once, so i cant really offer any help, accept get the hicas and wheel alignment looked at :laugh:
Mate i have the exact same problem i have ordered a hicas lock bar which should rock up soon ill let ya know if it fixes the problem. If i dont write back in hear just pm me cuz ill prolly forget :P
cheers allan
thanks 4 the help allan. i hope that fixes the problem. ill pm u in about a week or so
kun
Hey Kun
Sorry about the really late reply but i just finished installing the hicas lock bar then and it 100% fixed the steering problems everything is perfect now the car feels ALOT better to drive and the steering doesnt feel so sloppy now. :laugh:
Cheers iLEC
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
