  • Replies 493
Posted Images
Nice shots Sam.. Amusing, I got a 400D 2 weeks before I headed away on my trip - xmas day..
I got a 17-85mm Image Stabilising lens with it becuase I probably couldn't hold it still I think lol.. Might get a longer lens next.. this one is excellant though and would def recommend it if you were looking for an upgrade..
get the 17-40 f/4L.
I got the 17-85 because it's providing me with a bit more long distance ability..
Both are good lens's but most dont understand the difference inbetween the different series of lens's
Image stabilised lens's are really only benificial on the longer zoom units, it does not feature in many lens's under 70mm as at this range you can generally keep the camera still enough for enven a 1/2 second shot. Also in time you will have less use for the IS feature. My only IS lens is a 70-200 F2.8 LIS and its great for motorsport as it takes awsome panning shots...
So therefore if you were to have a 17-40mm there would be no need for IS and therefore the extra money gets spent of L series glass instread. In a perfect work we would all buy 5d's with 28-300mm LIS len's but not all of us have 9 grand...
So a 400D fitted with either a 17-85mm IS or a 17-40mm L series would both be great choices...
To be honest, we sell way more 17-40mm L series than the 17-85mm IS... Mainlly because the quality of the L series glass, also most people would but a 70-200 LIS as their second lens, as 40mm x 1.6 = 64mm in real terms which is plenty for portraits, landscapes & some minor macro work. I probablly use my 17-40 more than any other lens i own...
I got the 17-85 because it's providing me with a bit more long distance ability.. I think a 17-40 won't give me enough zoom.. oh well.. each to their own.. i've been extremely happy so far with it..
Cool. I ditched the 17-85 and got the 10-22 efs - 24-70L - 70-200L IS - 100 Macro 2.8 and next is the 100-400L IS :( I think that gives me pretty good coverage :laugh:
I'm no guru but here's what I'd say about these pics :(
Wrong time of day for this shot. With digital (particularly SLR's) you can take some of the best pics in conditions where you'd swear there wasn't nearly enough light. You said you have a tripod so don't be afraid of long exposures. Remote or cable shutter releases aren't dear and are very handy.
This second shot is more a composition thing than anything. I like the idea, (same as a lot of band photos where the group has a clear front-man or leader) except in those shots, as with this one, everything should have a fairly similar exposure. Mona's 33 is good (but half in its own shadow) while the Supra is overcooked on the front and in shadow on the side.
This shot would be perfect if shot at the right time of day. I like the angle but the lighting is wrong. You can see the far left of the shot in bright sunlight. Again, don't be afraid of long exposures and late-in-the-day shooting.
You know you're gonna crash into a wall, right? :mad: Make sure you don't show up in your own pics.
Not a bad angle or shot. You need to be careful with higher ISO numbers that you don't get too underexposed or your shots will be too grainy or noisy as was suggested for this shot. Remember that clean body panels reflect objects very well and that number plates can be evil with flash or can just plain old over expose themselves from the avialable light. Love the Nismo's and Federal's!
Shadows ruined this pic but that's not the only problem. Always be aware of your surroundings and make sure that nothing is growing out of the roof, boot or bonnet. The number of photos I've seen taken at Wollongong's South Beach where the car has a boot or roof mounted lighthouse is incredible :laugh:
Hope this helps you.
Adrian
Hey Adrian, thanks heaps for the feedback mate :laugh: appreciate it
this was the first time I have taken photos of cars that were not just parked at a cruise, and it was kind of rushed, but i definatly learned alot about sun light and shadows from this day :(
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
