If Anyone can help me I was looking for some information about the ENR34 2000 non turbo model AWD system as I am thinking about purchasing this car. What I wanted to know, is it the attesa? system or constant AWD and does anyone know of any way to disable the front wheels like you can on the attesa system? Any help would be good
https://www.sau.com.au/forums/topic/148899-enr34-awd-system/
I would put money on it being the attessa system. Nissan wouldn't R&D a new symeterical AWD system for the lower end of their market.
I scratch my head everytime someone asks how to disable the attessa system, I mean once you do - you really have a GTS with a heavy front end. One day I plan on owning my own GTR, and their is no way I would be changing the AWD system thats had millions of dollars spent in R&D on how it reacts to conditions, to adjust it to a backyarders idea of how it should perform.
Cheers
Sumo
sometimes its handy to be rwd for a bit
It's RWD most of the time! AWD is only engaged under certain conditions, like cornering, or rear-wheel slip.
Frankly, if you don't like the idea of Nissan's AWD system, don't get a car with it fitted; get a plain old common-or-garden RWD, like a Falcodore.
sometimes its nice to STAY in rwd
Cheers
Sumo
Oh okay cause I was under the impression that the attesa system was electronically initiated, and I heard that you can just remove the fuse to disable the attesa system which sends all the power to the rear wheels, with no front wheel drive at all. Also you can just install a switch which enables you to turn of the attesa, I'm not really sure if this is true or what? but if so thats great.
I'm pretty sure that only works with the R32s. If you do that on a 33 or 34, they go into "limp home" mode.
Which is why someone worked out that the switch by-passes the "limp home" function.
actually when u pull the fuse on the r32's it compltely kill the front wheels, but the r33 and r34 the clutch pack is tightened by a spring (or somethign along those lines). basicly they will still be in rwd mode when u pull the fuse.
I'm sorry I don't really undestand can you explain in dumbas language I don't know much about cars.
I'll put it simply for you as everyone else seems to be avoiding giving you an answer.
The R34 25GT FOUR does in fact use ATESSA. They are a great car and if you don't want something fast and like the idea of 4WD would be a great car.
Why bother disabiling the atessa? it's not like he's gonna drift it, and it ain't a crazy performance car so you should be fine.
If you want it to be RWD nissan also make model that is only RWD, therefore you will win either way.
Personally a 4 door auto with 4WD sounds like an awesome car to me.
  • 1 month later...
Hey Guys,
Sorry to dig up an old thread, but had some questions relating to the ENR34, Particualr the 2 Door, Manual, AWD version.
1. Is the drivetrain out of a r33GTR? or more similar to a stagea RSFour.
2. Would it be as simiple as drop in a rb26 and instant GTR?
Thanks
Mario
Hey Guys,
Thanks
Mario
I have a 2 door, manual r34 gt-four (had it about 2months now) and not many people really know the facts about their set-up, and this is only what i have found after reading up but mostly just driving the car.
1. Yes it uses the same atessa system as the gtr (which is only the computer side of things)
2. No its not a gtr gearbox, its definately not the r34 gtr box cause thats 6 spd, and the gt-four just doesnt "feel" strong like a gtr box, i would say its more along the lines internally of a rb25de box (same as a rb20det) or maybe a rb25det with the obvious casing changes to attach a transfer box.
3. No you cannot pull a fuse and turn it into rwd, that ONLY works for the r32's. Like previously said the car will go into a limp mode. Driving around like this will damage the front diffs clutches. Apparently you can disconnect the front shafts and it will go to rwd but the amont of effort to do it, just by a gtst.
4. HKS torque splitters can be fitted to adjust how much power is distributed to the front and rear. There is NO way to turn all the power to the rear, even with maximum power set to the rear, there will still be about 5% of the power still being sent to the front diff, which means no sitting on the brakes doing a big trev skid.
Although, with about 95% of the power going to the rear, that should be enough to step out around corners.
5. At the stock power level, the car just feels safe to drive in the dry around any corner. I can boot first gear take a 90 degree bend while smashing second and the ass end will attempt to come out but then the front just grips and puts you straight ahead, the car will understeer before it oversteers into a corner.
The wet is another story, since it is mainly rwd it will go VERY sideways if pushed but its a very easily controlled sideways since you can always feel the front helping you stay in control. So pretty much what i'm saying is if you want to go "drifting" like intial D in this car wait till its wet, go to somewhere quite, and have all the fun then, otherwise get a gtst.
6. The rb26 can bolt straight up and id say that once that was done, even in the dry the awd system will be smoking all fours around corners. A more budjet friendly solution is to get a stegea neo rb25det, change the front diff over with the stock gtfour one and your have a 206kw motor in your car cheap. Another good reason to go the stegea motor is that you stock gtfour harness will bolt up and the r34 ecu is flashable so you can get it retuned without spending dollars on a new ecu or piggy back.
Im planning to put a stagea motor in my car, and the more i learn about the gt-four i will post up cause its a bit of a mystery...
Edited by R34GTFOUR
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
