If Anyone can help me I was looking for some information about the ENR34 2000 non turbo model AWD system as I am thinking about purchasing this car. What I wanted to know, is it the attesa? system or constant AWD and does anyone know of any way to disable the front wheels like you can on the attesa system? Any help would be good
https://www.sau.com.au/forums/topic/148899-enr34-awd-system/
I would put money on it being the attessa system. Nissan wouldn't R&D a new symeterical AWD system for the lower end of their market.
I scratch my head everytime someone asks how to disable the attessa system, I mean once you do - you really have a GTS with a heavy front end. One day I plan on owning my own GTR, and their is no way I would be changing the AWD system thats had millions of dollars spent in R&D on how it reacts to conditions, to adjust it to a backyarders idea of how it should perform.
Cheers
Sumo
sometimes its handy to be rwd for a bit
It's RWD most of the time! AWD is only engaged under certain conditions, like cornering, or rear-wheel slip.
Frankly, if you don't like the idea of Nissan's AWD system, don't get a car with it fitted; get a plain old common-or-garden RWD, like a Falcodore.
sometimes its nice to STAY in rwd
Cheers
Sumo
Oh okay cause I was under the impression that the attesa system was electronically initiated, and I heard that you can just remove the fuse to disable the attesa system which sends all the power to the rear wheels, with no front wheel drive at all. Also you can just install a switch which enables you to turn of the attesa, I'm not really sure if this is true or what? but if so thats great.
I'm pretty sure that only works with the R32s. If you do that on a 33 or 34, they go into "limp home" mode.
Which is why someone worked out that the switch by-passes the "limp home" function.
actually when u pull the fuse on the r32's it compltely kill the front wheels, but the r33 and r34 the clutch pack is tightened by a spring (or somethign along those lines). basicly they will still be in rwd mode when u pull the fuse.
I'm sorry I don't really undestand can you explain in dumbas language I don't know much about cars.
I'll put it simply for you as everyone else seems to be avoiding giving you an answer.
The R34 25GT FOUR does in fact use ATESSA. They are a great car and if you don't want something fast and like the idea of 4WD would be a great car.
Why bother disabiling the atessa? it's not like he's gonna drift it, and it ain't a crazy performance car so you should be fine.
If you want it to be RWD nissan also make model that is only RWD, therefore you will win either way.
Personally a 4 door auto with 4WD sounds like an awesome car to me.
  • 1 month later...
Hey Guys,
Sorry to dig up an old thread, but had some questions relating to the ENR34, Particualr the 2 Door, Manual, AWD version.
1. Is the drivetrain out of a r33GTR? or more similar to a stagea RSFour.
2. Would it be as simiple as drop in a rb26 and instant GTR?
Thanks
Mario
Hey Guys,
Thanks
Mario
I have a 2 door, manual r34 gt-four (had it about 2months now) and not many people really know the facts about their set-up, and this is only what i have found after reading up but mostly just driving the car.
1. Yes it uses the same atessa system as the gtr (which is only the computer side of things)
2. No its not a gtr gearbox, its definately not the r34 gtr box cause thats 6 spd, and the gt-four just doesnt "feel" strong like a gtr box, i would say its more along the lines internally of a rb25de box (same as a rb20det) or maybe a rb25det with the obvious casing changes to attach a transfer box.
3. No you cannot pull a fuse and turn it into rwd, that ONLY works for the r32's. Like previously said the car will go into a limp mode. Driving around like this will damage the front diffs clutches. Apparently you can disconnect the front shafts and it will go to rwd but the amont of effort to do it, just by a gtst.
4. HKS torque splitters can be fitted to adjust how much power is distributed to the front and rear. There is NO way to turn all the power to the rear, even with maximum power set to the rear, there will still be about 5% of the power still being sent to the front diff, which means no sitting on the brakes doing a big trev skid.
Although, with about 95% of the power going to the rear, that should be enough to step out around corners.
5. At the stock power level, the car just feels safe to drive in the dry around any corner. I can boot first gear take a 90 degree bend while smashing second and the ass end will attempt to come out but then the front just grips and puts you straight ahead, the car will understeer before it oversteers into a corner.
The wet is another story, since it is mainly rwd it will go VERY sideways if pushed but its a very easily controlled sideways since you can always feel the front helping you stay in control. So pretty much what i'm saying is if you want to go "drifting" like intial D in this car wait till its wet, go to somewhere quite, and have all the fun then, otherwise get a gtst.
6. The rb26 can bolt straight up and id say that once that was done, even in the dry the awd system will be smoking all fours around corners. A more budjet friendly solution is to get a stegea neo rb25det, change the front diff over with the stock gtfour one and your have a 206kw motor in your car cheap. Another good reason to go the stegea motor is that you stock gtfour harness will bolt up and the r34 ecu is flashable so you can get it retuned without spending dollars on a new ecu or piggy back.
Im planning to put a stagea motor in my car, and the more i learn about the gt-four i will post up cause its a bit of a mystery...
Edited by R34GTFOUR
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
