sam5709 Posted December 27, 2006 Share Posted December 27, 2006 i have a pioneer 8650 head unit running the factory r33 speakers and a pioneer 800watt mono amp running a 1000watt (600watt rms) sub in box, recently my sub was taken out so i have just the amp that is still all wired in minus the sub, i have just bought some mtx component speakers and i want to hook them up to the amp as i dont have the sub any more! i hooked up the tweeters and the woofer to the crossover and i have run the amp to the crossover also, double checked all connections but there is not a noise out of them , i know the components work as i connected them to the wires that joined up to the headunit and they worked fine, but when hooked up to the amp they dont work, i was wondering is there anything else you have to do to get the connection from the amp to the speakers working? i thought id ask on here before i go and get a pro to look at it could it be the amp the is stuffed? any help/input will be appreciated regards sam Link to comment https://www.sau.com.au/forums/topic/148934-component-speakers-to-mono-amp/ Share on other sites More sharing options...
rocketboy Posted December 28, 2006 Share Posted December 28, 2006 What model Pioneer amp are ya running? Usually mono amps are specifically designed for subs and usually only play low notes i.e. there may be a low pass crossover built into the amp that prevents anything but low subsonic frequencies to be played. I wouldn't recomend using it to run components either. A set of components will show a 2ohm load on your amp, which may produce too much power for your speakers, you have to set the amp gains carefully when running overhead on your speakers ( more power than speakersare rated to handle). They will also be playing in mono - left speakers will play left and right music info. Same with the right side speakers. Hope this helps ya Link to comment https://www.sau.com.au/forums/topic/148934-component-speakers-to-mono-amp/#findComment-2778464 Share on other sites More sharing options...
