I got my tint done at tint-a-car in joondalup.
Didnt do a bad job but it was only 35% (darkest legal) tint.
Iv seen a photo of a skyline with TKO plates on it. Them plates used to be owned by Trent who owns TKO tinting and can add logos and graphics etc. See if it is him with the skyline and he might be able to give ya cheaper price. He is also a mobile tinting service (comes to your house or work).
http://www.tkotinting.com/
Let us know what he says if you make contact with him as im gonna get a ute tinted soon. Dont make the same mistake i made too - got my car tinted on a stinking hot day and couldnt open the windows for few days hahaha... Sweating like a pig.
Mr Keets - Let us know how you go with Trent's work as ill need a ute tinted when i sell my car...
Was gonna have my R tinted by TKO lastime but just ended up at tintacar as he was pretty booked out.
Are you the one with the GMG 32 with the garretts and the GTR decal on the bodykit???
  Dirty32 said:
Mr Keets - Let us know how you go with Trent's work...
.... GMG 32 with the garretts and the GTR decal on the bodykit???
Yes and Yes...I'm sure the decal is somekinda JDM dealer add-on. Except for one on GTROC its the only one i've seen.
SunPro in Mirrabooka did my Laser many moons ago in the desert smoke, did a pretty good job too. No bubbles etc with a lifetime gaurantee as long as you are the owner of the car....There is a good place in vic Park but the name escapes me >_< sorry.
Brother-in-law is a tinter for tint-a-car and did mine for nufin but I slipt him a pineapple for the cost of the tint... its a new slightly thicker film (18%)... I was going to go for the legal 35% but thought if the cops pull me over and want to sticker the car, they will just pick on something else if not my tint, my exhaust or ride height... I like the tint so to hell with what the cops think of it, legal or not... its what you want.
If you want a good job cheap I could ask him... but I have also used trent a few years back and I would use him if I didn't have someone in the family to do it for me!
Thanks Team
Thanks Scott, but ive already booked and its an excuse to take a day of work....well not much of an excuse at work but it works for me :) Its just a matter of choosing the film I suppose. Im probably going to get 35% but the darker stuff is appealing. Anyone have any issues driving with Darker tint?
Its only when you get into the 5% stuff do I find you have driveabilty issues (Can't see down sidestreets at night etc)
15% is fine, and is the one I normally go for.
Although on my GTR I thought all that black would be a bit dark (Police attention) so went the 30%.
Still in some lights they look very similar
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
