These injectors, are they made by Deatchwerks? is it lik saying im installing nismo injectors, instead im installing Deatchwerks injectors? has anyone used them? what are they lik? cos i lik the price.......
I have these injectors.. works fine for me. i have 240rwkw and max duty cycle i seen is 68%
i highly recommend them, they are high flowed injectors.
They are straight fit.. just like nismo.. fit on stock fuel rail, and comes with flow report of each injector.
Alot of Drag supra's in the states use them
check out their website..
http://www.deatschwerks.com/
Also if you do a search on deatschwerks on any car forum, people seem to say good things about them..
just stay away from Venom injectors.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780025
What size injectors do u have? Im aming at 250kw at the wheels
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780033
only had them in for a couple of months. no problems with them so far.
My tuner said he really liked them.
It was about $600 delivered.
you can also get some cashback offer too if you send your old injectors to Deathscwerks so it works out to be even cheaper.. i didn't do this though as i damaged the old injectors trying to pull them off the rail.. haha
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780057
ok cool was jus wondering how long they will last for. How long do injectors useally last for
Haha damn, i might be careful taking mine off then haha.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780062
I can't see why they would not last, my stock injectors were fine ( well not after i pulled them out) and i had about 180,000km on the clock.
Just keep an eye on max duty cycle on your PFC controller.
Bear in mind that it will show overall injector duty cycle not individual.
They flow test the injectors thoroughly and my injectors had something like 0.02% variance. Each injector is marked with a number which corresponds to the report.
yeah careful taking out your old ones, you can even pack them in the box that your new injectors came in and send them back to them.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780074
excellent thanks for that, good info. cheers
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780078
i'm in.... I'll give them ago
Cheers
So a guess mods rather than rebuild?
I went the mods route.
I got a fair few kms on my car.didn't know if i should sell it or mod it. took it to my tuner and he put the car on the dyno did som test on it and he said everything is healthy and if he was me he would keep the car.
i said i'm worried about the kms on the car and if i mod it something mite go wrong.. he said kms aren't everything you can have a 60,000km car with a bad motor and have a 200,000km car with a much more healthy engine. then i asked him if i should do rebuild first before modding it.. and he said what for? as long as the tune is good and safe you shouldn't have any problems.. alot comes down to the tune.
If you aren't chasing that much power then no need to rebuild what could be a very healthy engine.
anyway just my thoughts.
good luck with your decision.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780298
I'm no guru but it seems u can make good power with a rb25 motor in good condition without the need for new internals..I have been running 250+ for some time with stock internals...I did a compression test recently cos I was bored and everything was the roughly the same as when I got it tested 1 year ago before the mods...
verdict...its ok.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780553
Hey mate what state u in?
Also what time frame are u looking at doing this over?
I'm in vic mate you? thinking anytime from now untill late jan early feb!
they sound like a good deal..
Edited by RPR33
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780857
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
