These injectors, are they made by Deatchwerks? is it lik saying im installing nismo injectors, instead im installing Deatchwerks injectors? has anyone used them? what are they lik? cos i lik the price.......
I have these injectors.. works fine for me. i have 240rwkw and max duty cycle i seen is 68%
i highly recommend them, they are high flowed injectors.
They are straight fit.. just like nismo.. fit on stock fuel rail, and comes with flow report of each injector.
Alot of Drag supra's in the states use them
check out their website..
http://www.deatschwerks.com/
Also if you do a search on deatschwerks on any car forum, people seem to say good things about them..
just stay away from Venom injectors.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780025
What size injectors do u have? Im aming at 250kw at the wheels
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780033
only had them in for a couple of months. no problems with them so far.
My tuner said he really liked them.
It was about $600 delivered.
you can also get some cashback offer too if you send your old injectors to Deathscwerks so it works out to be even cheaper.. i didn't do this though as i damaged the old injectors trying to pull them off the rail.. haha
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780057
ok cool was jus wondering how long they will last for. How long do injectors useally last for
Haha damn, i might be careful taking mine off then haha.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780062
I can't see why they would not last, my stock injectors were fine ( well not after i pulled them out) and i had about 180,000km on the clock.
Just keep an eye on max duty cycle on your PFC controller.
Bear in mind that it will show overall injector duty cycle not individual.
They flow test the injectors thoroughly and my injectors had something like 0.02% variance. Each injector is marked with a number which corresponds to the report.
yeah careful taking out your old ones, you can even pack them in the box that your new injectors came in and send them back to them.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780074
excellent thanks for that, good info. cheers
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780078
i'm in.... I'll give them ago
Cheers
So a guess mods rather than rebuild?
I went the mods route.
I got a fair few kms on my car.didn't know if i should sell it or mod it. took it to my tuner and he put the car on the dyno did som test on it and he said everything is healthy and if he was me he would keep the car.
i said i'm worried about the kms on the car and if i mod it something mite go wrong.. he said kms aren't everything you can have a 60,000km car with a bad motor and have a 200,000km car with a much more healthy engine. then i asked him if i should do rebuild first before modding it.. and he said what for? as long as the tune is good and safe you shouldn't have any problems.. alot comes down to the tune.
If you aren't chasing that much power then no need to rebuild what could be a very healthy engine.
anyway just my thoughts.
good luck with your decision.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780298
I'm no guru but it seems u can make good power with a rb25 motor in good condition without the need for new internals..I have been running 250+ for some time with stock internals...I did a compression test recently cos I was bored and everything was the roughly the same as when I got it tested 1 year ago before the mods...
verdict...its ok.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780553
Hey mate what state u in?
Also what time frame are u looking at doing this over?
I'm in vic mate you? thinking anytime from now untill late jan early feb!
they sound like a good deal..
Edited by RPR33
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780857
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
