Just spreading the word!
"Spread the word Coastals is back for Summer !!
Meeting at the new central meetpoint Omni carpark @ City West located on the corner of Railway Pde and Sutherland St in West Perth.
Meeting at 8pm for a 9pm depart.
Seeya there !!"
KK :/
https://www.sau.com.au/forums/topic/149010-coastals-revival-saturday/
ok i read on antilag that its a monthly (or sumthing like that) cruise that starts in perth out goes along the coast or sumthin, a guy named dave used organise them but stopped and now "ricey" from antilag has started doing them again or sumthing alonge those lines :)
yeh had a few runs on the freeway, was nice, bout 5 of us sitting on 180 on roe highway just tryna catch up to the pack
as i left the truck stop i stopped at some lights, they went green and i floored it to 90 in a 70 zone, 20 over :) red and blue lights behind me, pull over and he asked me why i gunned it from the lights, i sed it was a stupid thing to do on my part, looked at my once again bald tyres and looked at my blue headlight bulbs again :) went to the his car and came back 10 minutes later and gave me my fine and told me to have a nice night
1 point and $100 :huh: that just goes to prove that not all cops are c**ts there are some good ones out there, i was waiting for another yellow and a huge fine :)
Nice Cruize.. I liked it.. I Just Made it in Time @ the Start of the MeetPoint then every1 was leaving as turned off my Engine hehe :)
Had a Few nice Runs Here n There..
-SeSaR
hey i think i saw your car a few times, do you have a drift wing now?
Unlucky Sam5709... Isn't it suppose to Be Double Demerit.. so it should of really been 2 Demerits then hehehe :cool:
No i don't have a Drift Wing.. I just Took of my Series 2 Wing.. But i do have a Big NISSAN sticker infront of my Windscreen.
White EVO9 MR Was Nice.. Popping Action as we were sittin @ da Lights.. n that Blue R34 GTR "GT51R" Looked Good. Caught up infront of the Pack.. then had a 3 Way Run wif "J Tuned" n Another 32.
-SeSaR
"... bout 5 of us sitting on 180 on roe highway just tryna catch up to the pack...
...1 point and $100 :cool: that just goes to prove that not all cops are c**ts there are some good ones out there, i was waiting for another yellow and a huge fine :rofl:"
So an average night out in the Skyrine :w00t: One point - no defect - semi positive interaction with the forces of goddness...man, got to be happy with that.
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
