I'm having some problems with my gearbox/clutch/pedal.
I was driving and the clutch pedal dropped away from my foot maybe 2-3cm. The clutch is still there but I have to push the pedal right up against the firewall to disengage it. I've tried to bleed the system and I'm certain there is no air in there, also replaced the slave cyclinder. The clutch doesn't feel as heavy as it used to be, I'd say it's 30% lighter right up until just before I get to the firewall then it's about the same as it used to be.
It's an OS Giken twin plate in a S1 R33 GTST and I'm totally stuck for ideas, the clutch works fine and doesn't slip at all but it's very hard to make it disengage so I've kept the car off the road until I can get it sorted out.
2 things I have noticed:
The bracket that holds the pedal in seems to be flexing sideways when I put the clutch pedal in, on further inspection I noticed there was 2 small 'tabs' holding the bracket together on the side closest to the transmission, these little tabs have broken though I don't know if it's related or not.
Secondly when I push the clutch in there is a fair ammount of movement of the actual master clyinder in the engine bay, it flexes out a good 3cm.
If it makes any difference the pedal dropped away while I was driving the car after changing the gearbox oil, I wasn't driving hard just giving the gearbox oil a chance to spread around and do it's thing. Any help is much appreciated guys I really can't afford to put it into a shop so soon after Christmas.
https://www.sau.com.au/forums/topic/149034-clutch-pedal-problem/
That's your problem - the pedal box has collapsed. You will need to remove it and get it welded back together, or replace it.
This happened to me as well ! The clutch pedal box is held basically together with spot welds. Just take it out and weld it back together and go around the seams as well ! Works a treat ! Then get yourself a brake master cylinder stopper to stop the firewall flex. Nobody makes, as far as I know, a clutch master cylinder stopper ( Ive built a custom one for myself that stops all firewall flex )
Hope this helps
lol.. this happened to me a few weeks back!
A good thing my mechanic did along with welding up the broken bit is do it twice, then do the other side just so you don't have to deal with the same problem in a few months!
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
