i have just found out that theres two types of q45 afm one will measure upto 400bhp and the other beyond that what i'm trying to find out is exactly how they differ inside is it a chip for reading the voltage and outputting it to the ecu or is it just a simple case of changing a few resistors to up it's capacitity.
cheers for any help help guys
https://www.sau.com.au/forums/topic/149044-q45-differences/
  • Replies 46
Actually this is partly down to me ;)
My q45 has u00 p60 in the serial number (same as pommeys) and maxes out (5.1v on the pfc) at 3/4 throttle around 70mph/3000rpm.
Thats running a 3037pro s on an RB25, unmapped and a guesstimated 300bhp at the wheels.
A friend has a Q45 with u01 p61 in the serial number and has no such problems with his 336bhp at the hubs.
https://www.sau.com.au/forums/topic/149044-q45-differences/#findComment-2779845
I have both a u00 p60 and a u00 p61.
Apart from the obvious fact that the later is from a later model car and newer the other difference is the plugs are slightly different.
If the car is untuned then is the AFM selected as the 90mm in the Power FC options even?
https://www.sau.com.au/forums/topic/149044-q45-differences/#findComment-2779855
I'll find out what the numbers on mine are to compare. Someone send me whatever the OTHER numbered one is, i'll wire it in and we'll have definitive proof.
And I want to run 20psi not 15psi like it is right now :P
https://www.sau.com.au/forums/topic/149044-q45-differences/#findComment-2780556
I couldnt get over half a bar of boost (8psi) without it maxxing :P
I've checked, double checked and rechecked all the wiring and PFC settings and everything was plumbed in as it should be.
Unforunately im not in a position to swap AFM's around on my car as its sat in a garage with the engine in a dozen pieces awaiting a 4th rebuild (some "tuners" should be shot) but it would be nice to have an answer to this for when she goes back on the road.
22680 61u00 a36-000 p60 - This is what I have on mine
22680 61u01 a36-000 p61 - This is the other one on a friends car
Edited by Gambit
https://www.sau.com.au/forums/topic/149044-q45-differences/#findComment-2780589
running out of load points is tunable
maxing the afm at 5.1v is not
if you are running out of load points (ie: it drops to row 20) then its tuneable and fixable with datalogit or power excel or fc pro
if you are maxing the afm at 5.1v some time early (like 3 grand etc) then something is horribly wrong. the afm is shagged, wrong unit, its dirty, bad earth or something? for those that have this problem at idle what voltage do you see? what version of powerfc? (ETC, VERSION)
if you give it a few revs at idle does it return to the same voltage each time?
the numbers in the voltage ramp which are visible in datalogit, fc pro and power excel only control how it is placed on the load map, that is it wont control when it hits 5.1v but more determine where certain voltages hit the load axis.
the numbers under SETTING, AIRFLOW control correction for load map placement, thse shift the final load axis up or down once it is calculated. again it wont affect voltage readings
https://www.sau.com.au/forums/topic/149044-q45-differences/#findComment-2780783
for curious sake the FC runs in this order
1) read AFM voltage (in volts, 0.00 to 5.10v)
2) look at SETTING, AIRFLOW (work out what AFM is selected) - (normal, powerintake, vg30, vh41 etc)
3) select "airflow" value from airflow ramp table for the corresponding AFM (this is a load number, ie: 5533 is an airflow "load" number)
4) apply AIRFLOW correction (from SETTING, AIRFLOW, NEXT) - (this is in % for AFM voltage scales, there are 8 of them i think)
5) with the final answer from #4 select INJ and IGN from maps where LOAD = P and RPM axis = RPM
https://www.sau.com.au/forums/topic/149044-q45-differences/#findComment-2780811
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
