yes but 300rwkw on an rb25 is different to 300rwkw on an rb30
it will flow different amounts of airflow for a given RPM
and i believe he was using ap eng RB20 which i think possibly the airflow ramps were a bit of out spec, ie: in the newer 5.10 RB25 PFC i think the ramps are bit better
  • Replies 46
they may flow different amounts throughout the rev range, but if peak power is the same and if it doesnt max out on one, it wont on the other either.
Edited by mokompri
I was running it off the rb20 base map to start, then we flashed the pfc over to the rb25 base settings (which work better) and we had a play with the datalogit adjusting :
the numbers in the voltage ramp which are visible in datalogit, fc pro and power excel only control how it is placed on the load map, that is it wont control when it hits 5.1v but more determine where certain voltages hit the load axis.
as well as something else to get the load points down to a tunable resolution.
dont ask me specifics, i just pay fer the tunes :P Cubes may remember exactly what we did...
In my expierence's with the Q45 (one that works) I've tuned 2 different RB25's with 2 different turbo's same Q45 AFM... Sorry didnt look at the number on it.
Engine 1: rebuilt engine, GT3540 turbo - running 30psi making 500rwhp maxing AFM 5.1vlts @ 5000rpm - engine was reving to 8k - peak power was made at 7500rpm
Engine 2: stock engine, HKS 3037s turbo - running 25psi making 430rwhp maxing AFM 5.1vlts @ 5500rpm - reving to 7k peak power made at 7k
We did not check these AFM with a multi-meter to see for sure that they were maxing out, these readings were from the apexi PFC.
The cars drove fine etc, had no troubles with tuning the AFR's
I know boost pressure does not = air flow through the meter.
The z32 is a much better afm for tuning the only thing you could do is to put it into a bigger 90mm pipe.
Doesnt a z32 have enough resolution for 300rwkws?
:S
369rwkw/24psi on my ole RB25 & Z32
peak power the same for both motors, wont mean the same airflow for both motors (if different capacities) if im not mistaken
power is determined by how much fuel and oxygen is burnt ie mass of fuel and mass of oxygen/air
afm measures *mass* of air, so regardless of engine capacities a 2L and 3L both producing 100kw at whatever rpm, are both consuming the same mass of air.
Edited by mokompri
Wolf3D... great step up :lol:
mokompri: What are you trying to say? If 2 differnet engines make eg: 300rwkws and if the AFM does not max on one it should not be max on the other becaues they have the same peak power.
You'r claim eg:
Car: Make 300rwkws at 7000rpm - None Maxed AFM
How do you know its not maxed, regardless of the peak power like I said AFM's generally max at peak torque point or close to it in the engine, whether its 5000rpm or 7k a MAX voltage of 5.1 is the limit.
Too many variables,
Were talking turbo's not superchargers!
Let me know how you go adrian! :)
doesnt matter whether its a supercharger or a turbo..
what im saying is, that afm's measure mass of air
the peak consumption of mass of air is at max power, not at max torque (unless that rpms also has max power), for any given period of time.
so yes, 2 engines making 300rwkw will show the highest voltage on the afm at peak power, and since they both make 300rwkw peak neither will max or both will max.
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
