hey guys im lookin at getting rid of my fuel reg for regency.to me it looks simple the hose that goes in the side and the hose that goes out the bottom do i reconect them 2 gether?????also on the top of the fuel reg it looks like a breather comes of there but theres no pipe on there its just open whats the go there????
also another question on my fuel reg gauge its got the exact psi/bar that im running set on it.is this for a reason??????and how much would the regulator be worth????
no pics yet :P
https://www.sau.com.au/forums/topic/149077-fuel-regulators/
also another quik question...on the bottom of the throttle body theres a pipe on each side and looks like they go strate thru to each other.but no hoses on these.......where should i run a couple of hoses.just to make ita bit more legit.i was just gona run them to each other like a loop????
https://www.sau.com.au/forums/topic/149077-fuel-regulators/#findComment-2780679
I would definitely be taking your car to a mechanic to get these things rectified/removed mate - one small misstep on your part and you'll blow up your car by not giving it enough fuel in about 2 microseconds.
https://www.sau.com.au/forums/topic/149077-fuel-regulators/#findComment-2780909
That line is your plenum pre heat(great in Europe and Japan) not much use in Adelaide.
The line starts at the front of the engine (on the fuel injector bracket) then into the front of the plenum. The other side disapears down the back of the block.
https://www.sau.com.au/forums/topic/149077-fuel-regulators/#findComment-2781369
no pics yet ;)
The "breather" is a vacume line and plugs into the front corner of the plenum.
https://www.sau.com.au/forums/topic/149077-fuel-regulators/#findComment-2781376
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
