Hey,
Pulled out the rear seats of my r32 gtst and discovered cut wires. Not sure if this is factory wiring or amp wiring?
Three thin wires are duct-taped at the end, and one fat cable...
My rear speakers never worked when i got the car. Could that be the rear speaker wires?
Thanks
https://www.sau.com.au/forums/topic/149085-cut-wires-found-under-seat/
nah thats not rear spks ( they are are grey leads and there are two of them.) looks like a dealer add on. trace it back through you will either find the box it attached to (tucked behind a panel) or the other end ;)
nah thats not rear spks ( they are are grey leads and there are two of them.) looks like a dealer add on. trace it back through you will either find the box it attached to (tucked behind a panel) or the other end :happy:
Well i pulled out the headunit and found a 8pin? plug and wire. I think its a cd stacker wire and they just cut it off under the seats?
The other 3 wires i couldnt find attached to the headunit so gave up on them.
Pulled off the stock amp and will put my own amp for the rears.
Cheers
