hi there..
lately i have noticed that my factory boost guage in my 32 always seems to be showing a bit of boost, even at idle, its always under 0 at idle but it sits a bit above -7... the needle goes back down when the car is off so its not a stuck needle, but was wondering if this is common or if my turbo etc. could be stuffed?
cheers
https://www.sau.com.au/forums/topic/149090-quick-factory-boost-guage-question/
Manifold vaccuum is exactly that, negative pressure (vaccuum) in the inlet manifold. The engine, while idling, does not produce enough exhaust gasses to spin the turbine, therefore the engine just draws air without the compressor forcing it in. Basically like an N/A engine would.
I think i just made a fool of myself :happy: , feel free to correct me, i'm here to learn too :D .
yeah i get what your saying there.. dont know enough myself to know if thats right or not but it sounds like it could be.. what worries me though is i've had the car almost two years and never really noticed it doing that before lol...
www.howstuffworks.com
useful
yes i started reading some of that, and from the wikipedia site.. but i was more wondering why it does it and idle, and at 100km/ph, and yet i havent ever seen it doing it much before.. i was wondering if it meant my gauge has been a bit unreliable or if i should be getting the turbo looked at... but then again, it might be completely normal and i can go back to sleeping at nights lol...
I can assure you it's normal :(
if you have only just started noticing it, it may be that your gauge hasn't been working properly till now.
the vacuum is caused by the butterfly in the throttle body being shut, like holding your hand over the end of a vacuum cleaner, therefore it creates a vacuum in the manifold. as you open the throttle the vacuum gets less and less until you have the throttle open enough where the engine can suck in as much air as it is using (0 vacuum pressue).
that is a basic rundown on what happens.
As mad082 says, that's vacuum. Boost is positive pressure, so anything less than 0 is vacuum.
Also note that the guage is in millimeters of murcury mmHg, not psi or bar or cowdung. ;o)
So... if you are cruising down a big hill and not accelerating, the engine is still turning quite quickly, and because of the compression in the cylinders, air is being pushed out the exhaust, but with the throttle closed it's hard for the motor to take any air in to match what is going out... subsequently, the vacuum in the manifold increases, and you get closer to -7mmHg (roughly 14psi) in vacuum.
Same thing at idle or slow cruising, but not as exaggerated as the above scenario.
Edited by RANDY
just so people with aftermarket boost gauges don't get confused, most aftermarket boost gauges read either psi or bar in positive, and most that read psi positive boost don't read psi in vacuum. in vacuum they read inches vacuum or something like that.
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
