hi there..
lately i have noticed that my factory boost guage in my 32 always seems to be showing a bit of boost, even at idle, its always under 0 at idle but it sits a bit above -7... the needle goes back down when the car is off so its not a stuck needle, but was wondering if this is common or if my turbo etc. could be stuffed?
cheers
https://www.sau.com.au/forums/topic/149090-quick-factory-boost-guage-question/
Manifold vaccuum is exactly that, negative pressure (vaccuum) in the inlet manifold. The engine, while idling, does not produce enough exhaust gasses to spin the turbine, therefore the engine just draws air without the compressor forcing it in. Basically like an N/A engine would.
I think i just made a fool of myself :happy: , feel free to correct me, i'm here to learn too :D .
yeah i get what your saying there.. dont know enough myself to know if thats right or not but it sounds like it could be.. what worries me though is i've had the car almost two years and never really noticed it doing that before lol...
www.howstuffworks.com
useful
yes i started reading some of that, and from the wikipedia site.. but i was more wondering why it does it and idle, and at 100km/ph, and yet i havent ever seen it doing it much before.. i was wondering if it meant my gauge has been a bit unreliable or if i should be getting the turbo looked at... but then again, it might be completely normal and i can go back to sleeping at nights lol...
I can assure you it's normal :(
if you have only just started noticing it, it may be that your gauge hasn't been working properly till now.
the vacuum is caused by the butterfly in the throttle body being shut, like holding your hand over the end of a vacuum cleaner, therefore it creates a vacuum in the manifold. as you open the throttle the vacuum gets less and less until you have the throttle open enough where the engine can suck in as much air as it is using (0 vacuum pressue).
that is a basic rundown on what happens.
As mad082 says, that's vacuum. Boost is positive pressure, so anything less than 0 is vacuum.
Also note that the guage is in millimeters of murcury mmHg, not psi or bar or cowdung. ;o)
So... if you are cruising down a big hill and not accelerating, the engine is still turning quite quickly, and because of the compression in the cylinders, air is being pushed out the exhaust, but with the throttle closed it's hard for the motor to take any air in to match what is going out... subsequently, the vacuum in the manifold increases, and you get closer to -7mmHg (roughly 14psi) in vacuum.
Same thing at idle or slow cruising, but not as exaggerated as the above scenario.
Edited by RANDY
just so people with aftermarket boost gauges don't get confused, most aftermarket boost gauges read either psi or bar in positive, and most that read psi positive boost don't read psi in vacuum. in vacuum they read inches vacuum or something like that.
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
