hi there..
lately i have noticed that my factory boost guage in my 32 always seems to be showing a bit of boost, even at idle, its always under 0 at idle but it sits a bit above -7... the needle goes back down when the car is off so its not a stuck needle, but was wondering if this is common or if my turbo etc. could be stuffed?
cheers
https://www.sau.com.au/forums/topic/149090-quick-factory-boost-guage-question/
Manifold vaccuum is exactly that, negative pressure (vaccuum) in the inlet manifold. The engine, while idling, does not produce enough exhaust gasses to spin the turbine, therefore the engine just draws air without the compressor forcing it in. Basically like an N/A engine would.
I think i just made a fool of myself :happy: , feel free to correct me, i'm here to learn too :D .
yeah i get what your saying there.. dont know enough myself to know if thats right or not but it sounds like it could be.. what worries me though is i've had the car almost two years and never really noticed it doing that before lol...
www.howstuffworks.com
useful
yes i started reading some of that, and from the wikipedia site.. but i was more wondering why it does it and idle, and at 100km/ph, and yet i havent ever seen it doing it much before.. i was wondering if it meant my gauge has been a bit unreliable or if i should be getting the turbo looked at... but then again, it might be completely normal and i can go back to sleeping at nights lol...
I can assure you it's normal :(
if you have only just started noticing it, it may be that your gauge hasn't been working properly till now.
the vacuum is caused by the butterfly in the throttle body being shut, like holding your hand over the end of a vacuum cleaner, therefore it creates a vacuum in the manifold. as you open the throttle the vacuum gets less and less until you have the throttle open enough where the engine can suck in as much air as it is using (0 vacuum pressue).
that is a basic rundown on what happens.
As mad082 says, that's vacuum. Boost is positive pressure, so anything less than 0 is vacuum.
Also note that the guage is in millimeters of murcury mmHg, not psi or bar or cowdung. ;o)
So... if you are cruising down a big hill and not accelerating, the engine is still turning quite quickly, and because of the compression in the cylinders, air is being pushed out the exhaust, but with the throttle closed it's hard for the motor to take any air in to match what is going out... subsequently, the vacuum in the manifold increases, and you get closer to -7mmHg (roughly 14psi) in vacuum.
Same thing at idle or slow cruising, but not as exaggerated as the above scenario.
Edited by RANDY
just so people with aftermarket boost gauges don't get confused, most aftermarket boost gauges read either psi or bar in positive, and most that read psi positive boost don't read psi in vacuum. in vacuum they read inches vacuum or something like that.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
