I'm getting a custom exhaust made up about half way through next month. All I need to supply is the muffler. I was just wondering what all your thoughts were on lukey mufflers. Saw some today and they look alraight, but at the end of the day I don't want something that just looks good. Don't want a droney sounding exhaust. Anyone have one?
https://www.sau.com.au/forums/topic/149092-lukey-exhaust/
Cool, sounds good. Think I might pick one up, as long as no one on here says any different. I was just trying to get something a bit different to the usual milo tin look. (not that there is anything wrong with it) ;)
https://www.sau.com.au/forums/topic/149092-lukey-exhaust/#findComment-2781053
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
