Car Running Hot!
shredder667
 Share
car in question is an r32 gtr. this used to happen occasionally but at the moment (i've been driving it quite frequently) its constant. without the ac on i can feel hot air coming thru the vents and at my feet as well. temp gauge is a tiny bit above half way. is that normal or is that running pretty hot? not sure what it could be. car had a full fluid and filter service just a couple weeks ago. any clues? cheers guys. oh also, last night the speedo needle was shaking heaps.
press the recirculate button when a/c is off. fixed.
are you going off the stock temp gauge or one with deg? if so, what temp does it get up to?
anyone know what the safe temp range is ? mine sits anywhere from 80-95 depending on driving
Speedo needle shaking? mine jumps around when sitting at 100-110kmh
yeah its just annoying cuz it didn't used to do that. thought in some crazy way it had something to do with the heat. i'm going of the stock gauge so i'm guessing it may not be so accurate anymore. and yeah, heat problem fixed. can't believe how dumb that was.
If you get hot air when you have the vent open to outside its probably the heater core tap getting stuck open. Mine used to blow hot air at me when i was on the freeway and id stand on it for a few seconds. Probably the increase in water flow thru the core pushing the tap open...
a bouncing or shaking speedo needle is a really strong sign that your speedo cable needs replacing. that cable also controls the steering to some extent. worth replacing it before it dies
Not necessarily true. Before my speedo cable let go, it was working perfectly, no shaking or bouncing, it died suddenly.
And I got it fixed, got an aftermarket one installed profesionaly and now the sucker is bouncing like crazy.
Oh well.
Oh well.
have you had it looked at? maybe ask the blokes that fitted it for you why the needle is bouncing.
i have known of 4 32gtrs a 32gtst and a 180 that all had bouncing needles (my gtr included) and they all turned out to be worn speedo cables. i replaced my cable myself with a genuine new cable from nissan. works perfectly with both speedos that ive had in my car.
im not saying that the speedo cable IS the fault, just a very good chance it is :)
 Share
    • Hi fellow SAU members, I want to put coupe tail lights on my R32 sedan. I have been told it was as easy as changing the boot lid and the tail lights and possibly the rear bar. I have since found out that this is incorrect after buying the lights and boot. The coupe boot dosnt allow the boot to oprn on a sedan and the tail lights won't fit either. Has anyone done this or seen it done and could help me out with some guidance or instructions to get it done.
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
