Hey guys,
I just found this license plate that I still have after selling my R33 nearly 18 months ago.
It's for show purposes but I used to sit it in my front window (hard core street racer and all).
Anyway, as my next purchase will be an R32 I'll no longer be needing this.
First in, best dressed, and you can have it for free because I'm nice.
No I'm not posting it (for any out-of-staters who want it :P ), you can just pick it up from my place.
Andrew. ;)
https://www.sau.com.au/forums/topic/149099-free-to-good-home/
I'd like to have first dibs on the next next next offer, if it happens!!
Leigh your selling as well..............so when R3sp3ct sells and then you sell gimme gimme gimme!!!!!!!!
PS I'm NOT selling.
i am not selling any time soon. I need to make more $$$ before i can sell minimum of 9 months but more likely 1 - 2 years :happy:
And here's me thinking you were on the big $$$$$, flash looking motor, just brought some real estate [didn't you?], well dressed, lastest fashions, out cruising all the time, nothing but the best!!!!
I thought you were on the GTR trail?
No that’s Amaru your thinking off :(
"just brought some real estate" - I own an apartment but this is the main reason for having no money + the fact i am saving to buy a house... once we get the house i will get the car...
*Sleazy Voice* First you get the house... then you get the car... then you get the lady's :)
[/color]
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
